swaping out ignition module 2010 flhx
Old May 2, 2013 | 07:31 PM
SmittyFXDL's Avatar
SmittyFXDL
Default swaping out ignition module 2010 flhx
While changing my fork oil I noticed some cracking or deterioration around the ignition module that the ignition post and key switch slide into. Its the black rubber casing that holds the tumblers. Upon closer inspection it has cracks all around the casing and I am going to replace tomorrow.
In looking at the manual, it says theres a special tool needed that very long and narrow to detach or release the wires from inside the module. Is this tool needed or does anyone know a work around for this? Appreciate any advise on swapping this out. Thanks.
Old May 4, 2013 | 12:17 AM
ReidRik_Von's Avatar
ReidRik_Von
I'd love to see some photos of the swap you have going on. I have a project going here where I am interested in using an ignition switch from a fairing model on my FLHP so that I can mount a 4" speedo next to my tach that is mounted between my bars using a 2-up gauge cluster.
In looking at my 09 manual it looks like one could possibly use a long standard screw driver rather than the HD-45961 tool. Good luck!
Old Jun 1, 2013 | 10:53 AM
Gary H's Avatar
Gary H
I'm interested in this too. I ran my wiring internally in the frame this winter when I raked it and did mine without the tool. I broke the clip that holds it in. I couldn't figure it out and got too rough with it.
Old Jun 1, 2013 | 11:08 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Based on the way the tool looks, it would appear a large screw driver with the appropriate length shank would work in a pinch.
Kevin Spencer
May 28, 2019 08:02 AM
Just Me
Mar 8, 2015 05:11 PM
gmc
Aug 9, 2011 07:34 PM
marcparnes
Jan 1, 2010 10:29 AM
FFeric
May 16, 2009 11:36 PM
