Head Temp?
Old May 2, 2013 | 07:33 PM
GMRO's Avatar
GMRO
Default Head Temp?
What rule of thumb do you use when thinking of head temp before removing plugs?
Sure overnight and stone cold is best right? But if you just back from riding and wanted to pull plugs to change them or else how long do you wait or what feeling temp on the heads do you wait for? Wouldn't think you would want to torque in a new set with the heads hot? Or remove them for that matter when hot right?
Thanks!!!
Old May 2, 2013 | 07:38 PM
smitty901's Avatar
smitty901
Put your hand on the head near plug if it is warm to the touch walk away come back latter.
You can get way with it but it not worth the problems if you mess with it warm.
Old May 2, 2013 | 07:40 PM
Lowcountry Joe's Avatar
Lowcountry Joe
All plug removal/install should be done with those aluminum heads cold. The plugs and the heads need to be relatively the same temperature so once seated they expand and contract together. Install a cold plug in a hot head and you could cause some needless damage to the threads.
Old May 2, 2013 | 07:41 PM
Juan L's Avatar
Juan L
Moderator
I say remove them while they are smoking hot, burning yourself on everything possible until you finally get the little lava laden jewel out of the hole and it is so hot you can't hold it long enough to inspect it properly. That is what I like to do.
How about you GMRO?
Old May 2, 2013 | 08:20 PM
geezer glide 56's Avatar
geezer glide 56
I honestly don't think it matters...I have changed plugs for years in hot engines...cold engines and never had any issues or thread damage.
Old May 2, 2013 | 08:38 PM
Bagger Jim's Avatar
Bagger Jim
+1....
Old May 2, 2013 | 09:05 PM
brewdog's Avatar
brewdog
Here's what do. Learned this from a motorcycle mechanic years ago. Buy a 20" box fan from wallyworld prop it up on the floor pointed toward both cylinder heads from the side of the bike. Doesn't matter which side, just aim it and let the CFM of the fan draw the heat off the engine naturally. I place the fan at a distance of 3 feet or so and tilt it at a slight angle to make sure the blows across all the fins on both cylinders. Turn it on high and come back in 20 minutes. Works like a charm.
Old May 3, 2013 | 07:14 AM
GMRO's Avatar
GMRO
How about you GMRO?
For years I've been using an oven mit and hot-dog tongs... Usually I drop the plug and it smacks off the engine and falls into the dirt on the ground. That's when I began using the tongs. I blow the grit off the plug and just restall with my BINFORD trusty "6500 max radical torque wrench" set to about 400ft lbs just to be sure they won't come out.
ALL GOOD!
Thanks for the help!
P51Driver
2018+ Softail Models
20
Jul 31, 2019 07:33 PM
junkyardscrounger
Exhaust System Topics
Aug 4, 2011 01:59 PM
Jackstraw
Aug 3, 2011 10:04 AM
Cabo Bob
Apr 21, 2008 02:17 PM
masterblaster
Jan 27, 2008 05:19 PM
