Cleaning White Wall Tires
Old May 5, 2013 | 07:47 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
toilet bowl brush goes all the way around without jacking or rolling,castrol power clean white as ever.
Old May 5, 2013 | 08:00 PM
scotracy's Avatar
scotracy
Originally Posted by taconite
Sounds crazy but a SOS pad works great, and does not damage the surface. A friend got me on them and I was very skeptical, but they work fantastic. There is a soap built into them already. Just rinse and wipe.
He is right. I have tried all sorts. A good brillo pad is easy and cheap. Done in minutes, and not much elbow grease involved.
Old May 5, 2013 | 08:03 PM
alana420's Avatar
alana420
Stage I
Quick & easy... Mr Clean Magic Eraser!
Old May 5, 2013 | 08:27 PM
Backroadryder's Avatar
Backroadryder
I agree with the Brillo/SOS pad solution. Gets them white without much effort.
Old May 5, 2013 | 08:41 PM
2heritagespringers's Avatar
2heritagespringers
Default laquer thinner
Been cleaning wide white walls for years. Clean them with soap and water than dampen a cloth with laquer thinner and wipe them down. Best way I have found.
Old May 5, 2013 | 08:59 PM
Ron "Gunner" Retzlaff's Avatar
Here is the way that I clean mine in like 3 minutes.
https://www.hdforums.com/forum/detai...-cleaning.html
Old May 6, 2013 | 01:31 AM
PHXBiker's Avatar
PHXBiker
Brillo or SOS
Old May 6, 2013 | 04:23 AM
The Cheesehead's Avatar
The Cheesehead
Westleys Tire Bleach and an old scotch brite pad (oh, and a shot of Crown Royal). I use the rough side of the Scotch Brite pad on the WWW and the wiskey, well I use that one one me! Use a jack and do the spokes/wheels at the same time. Find a long skinny scrubber for the spokes, if you have those. If you are able to easily remove your bags also, do that and you'll get that rear tire done in no time flat.
Isn't laquer thinner bad for the rubber on the wheels? I've never heard of doing it that way before, interesting though.
Old May 6, 2013 | 05:02 AM
GLACIERPEARL's Avatar
GLACIERPEARL
On the jack, Westleys bleach white, magic eraser,....WALA !!
Old May 6, 2013 | 05:03 AM
Badbagger09's Avatar
Badbagger09
I use a brillo pad and some softscrub with bleach...
