Part #: AT-100
The first is a "dual O2 sensor" version made specifically for Harley Davidson models. It comes with two O2 sensors, one control modules, CAN connection cables, and custom length sensor cables. It also includes a built in power connector that plugs directly into the bikes’ wiring harness for easy connection.
Part #: AT-100
The first is a "dual O2 sensor" version made specifically for Harley Davidson models. It comes with two O2 sensors, one control modules, CAN connection cables, and custom length sensor cables. It also includes a built in power connector that plugs directly into the bikes wiring harness for easy connection.
What is the one that comes with 2 control modules? is one for the front cyl and one for the rear? trying to get the rear cylinder to run cooler and will this one be better?
Like the last post above, AT-100B will have everything you need. It already comes with two modules and is a plug and play type. I have it on my bike now and its fantastic. As far as being better? Not sure...is it great? Yes. Hope this anwers your question.
trying to find out which one to buy will the one with 1 module still tune both cylinders separately? or can i use the one with 2 module?am a newb when it comes to this
