true duels
Old Feb 20, 2007 | 10:13 PM
Two As One's Avatar
Two As One
Default RE: true duels
I have a 97 Ultra,motor is built alittle,310 cams.
True duals-- vance and hines header pipes with
screamin eagle mufflers. Don't have dyno numbers,
pull a trailer alot loaded to the GILLS and ride double
up, I think it does really well. Put your true duals on
and increase your cam. Just a thought.
Old Feb 20, 2007 | 10:21 PM
CNC WHEEL GUY's Avatar
CNC WHEEL GUY
ORIGINAL: Bryan TTM
if i felt like i needed more torque...i'd first add torque cones....then i'd STROKE IT ...true duals belong on a bagger IMO...90ftlbs @ 2000rpm, plenty of grunt
Yeah, with the horsepower and torque you are running, I can see why you would NEED to have more power
Old Feb 20, 2007 | 10:24 PM
DAVETHEBUILDER's Avatar
DAVETHEBUILDER
Thank's for all the feed back, torque cones was going to be my next question, I think I'll tryem before I get rid of my pipes, my dyno guy said he would let me try a different set of pipes and if I didnt likem I didnt have to takem
Old Feb 20, 2007 | 10:30 PM
xxxflhrci's Avatar
xxxflhrci
ORIGINAL: DAVETHEBUILDER
Torque cones go in the wrong end of the pipe to do any good. You would be better off with some lollipop baffles in the other end.
When I put on V&H Duals, I could tell a definite loss on the bottom end. I made some lollipop baffles and put them in front of the mufflers. I also had to add a DFO on top of the Stage I to enrichen the fuel circuit. The bike runs pretty stout now.
My lollipops are 1" washers welded on to 1/2" studs. You can turn them like vanes to crudely tune your exhaust.
[IMG]local://upfiles/17633/FC3E452BED4F4D2AA9EE4B1307F771C1.jpg[/IMG]
[IMG]local://upfiles/17633/128A115EE8054464B955320E067DBC2B.jpg[/IMG]
Old Feb 20, 2007 | 10:55 PM
JLHOG's Avatar
JLHOG
I have Hooker True Duals on my bike and feel plenty of torque. Some say you loose a little torque with the True Duals, but I dont think it is anything but a dyno could tell. The looks far outweigh the lose!!! Besides I like having two hookers hanging on my bike lol
Old Feb 20, 2007 | 11:43 PM
Dalton's Avatar
Dalton
I ran Rinehart True Duals on my 95" 03 RKC, made HP 102 and TQ 115 with other engine mods, no torque problems at all and still got 45mpg if I wore a wrist splint.
In the middle of building a 103" 07 Ultra, and sticking with Rineharts, looks and less heat are important to me. If I loose a couple of foot pounds, I will live with it - am hoping to hitTQ 120 -125 with this build.
Old Feb 20, 2007 | 11:57 PM
ultra2006's Avatar
ultra2006
RH TD working fine for me, just put them on, with all the other stuff.
Old Feb 21, 2007 | 02:08 AM
rideon's Avatar
rideon
My buddy just had the same build as me done, identical bikes, same builder. He has stock header pipes with V&H ovals. He got 96.5 HP and 101 torque, compared to my 101.10 HP and 105 torque. Yes I got slightly better peak numbers but he has 15 ft pounds more torque at 2500 rpm! That makes for a pretty snappy bike with considerably more grunt right where you need it. My rineharts are getting **** canned later this week for a fat cat with quiet baffle to see what this puppy will realy do!
Old Feb 21, 2007 | 03:43 AM
FLWanderer's Avatar
FLWanderer
I also have the V & N true duals with the V & N Ovals.....Big sucker ....and my last dyno shows
73.38 hp
80.87 tq
I have no problem with those numbers...and most of the time two-up...still scoots right along.
Been getting around 42 mpg....which is also okay.
2004 Electra Glide Classic
Old Feb 21, 2007 | 06:51 AM
PapaTravis's Avatar
PapaTravis
saw a bike somewhere with a 2 into 1 pipe on the right, and a fake pipe on the left, from the back you could see no difference and from the left side as well. Can't remember where I saw it, but it was nice, best of both worlds, if I could only figure out how to do it. I am running sampson straight fishtails...maybe the worst you can run, but for me, the look is what I have to have. -Travis
