headlight doesnt always come on
Old May 5, 2013 | 10:46 PM
gillford's Avatar
gillford
Default headlight doesnt always come on
my headlight on my 2011 ultra does not come on some of the time when turning on ignition then it will come on, at least for now. any one having this problem or know any information
Old May 6, 2013 | 12:36 AM
my67pnycar's Avatar
my67pnycar
I would start checking for loose connections. Not good when your headlight goes out riding at night. Good luck.
Old May 6, 2013 | 09:46 AM
LeadSSled's Avatar
LeadSSled
I had that problem with mine and it turned out to be a bad bulb. One of the rivets holding the spade terminal strap into the bulb housing was loose causing an intermittent connection. It was the original bulb with about 6K miles on the bike, but a new bulb fixed it. Easy to check - if you can wiggle the spade terminals on your bulb, this is probably your issue too.
Old May 6, 2013 | 10:30 AM
Ultra103's Avatar
Ultra103
If it's still under warranty take it back and let them fix it.
Old May 6, 2013 | 11:53 AM
hamnhog's Avatar
hamnhog
Had a very similar problem with mine. Turned out to be the headlight relay. $6 fix.
Old May 6, 2013 | 12:59 PM
UUNetBill's Avatar
UUNetBill
Yeah, but it's those intermittent electrical issues that can just drive you batshit crazy...
Old May 6, 2013 | 08:01 PM
gillford's Avatar
gillford
thanks guys for your input i will get on it ,and thanks again,
Old May 7, 2013 | 03:40 AM
ParaGrunt's Avatar
ParaGrunt
On my '07 FLHX, the plastic plug had one lead melted due to an incomplete connection. I cut the plastic POS off and replaced it with a ceramic plug. I believe it cost $5 for two. No problems since.
Whiskyjock
Jul 27, 2019 06:41 AM
JonnyBlaze
May 10, 2014 04:10 PM
DCRANER
EVO
18
Oct 1, 2013 01:58 PM
creekhed1
Aug 17, 2009 06:21 PM
eric95
Oct 21, 2008 11:24 AM
