Octane boost
Old May 8, 2013 | 05:42 AM
Rodzilla6's Avatar
Rodzilla6
The local dealer has some octane booster that comes in a one timed use plastic package that would fit in your pocket and wont leak. Throw a couple in your saddle bag for emergencies.
Old May 8, 2013 | 06:01 AM
fat daddy's Avatar
fat daddy
Snake oil !!!
Old May 8, 2013 | 06:46 AM
Softy 103's Avatar
Softy 103
103 with 254e's, heavy breather, race tuner, Burly heads, fatcat 102 hp. 115 tq. and runs like a champ on 87 or 89.
Old May 8, 2013 | 10:04 PM
Potato_Potato's Avatar
Potato_Potato
I keep a bottle in the saddlebag when traveling.
FYI: Toluene is a solvent that you can buy cheap by the gallon at paint stores. It is also an octane booster. In the 80s it was used by Formula 1 teams at 86% by volume.
I can't remember the recommended ratio for non-turbo Formula 1 use but Google has it. I do know that a gallon will last you a lifetime. It is is similar to Ethanol in that it is corrosive to fuel system components so I use it only when needed and at the minimum ratio needed.
Old May 13, 2013 | 02:21 PM
ohioflhs's Avatar
ohioflhs
In my experience, they all work. If you have a pinging engine and use it the ping will go away. My biggest question is, is it safe for the bike? I doubt it. At least not if used all the time. Used occasionally I don't think it will hurt.
Old May 13, 2013 | 09:47 PM
RoadGlideGary's Avatar
RoadGlideGary
Default Octane enhancer
Double down on the double post!
Last edited by RoadGlideGary; May 13, 2013 at 09:52 PM. Reason: Double post bonus!
Old May 13, 2013 | 09:50 PM
RoadGlideGary
Rocket Fuel - formulated for HD engines only. If you ever get bad gas ( not from what you ate) in your tank it will fix the problem. I use it in every tank especially when I gas up in small towns where the last gas tanker came in long long ago.
ajnigli
Sep 27, 2017 09:59 PM
magnum629c
Aug 4, 2014 04:24 PM
Mithion
Jun 13, 2013 09:50 PM
2kanzam
Sep 3, 2008 10:49 PM
dawg
Jul 18, 2006 12:46 AM
