I've been riding belt drive Harleys since 1990 and never had one break. I had a stone cut one, which I changed about 4k miles later, because the wound started to spread. Breaks so soon after each other is a real bummer. Check tension is correct with your new belt, as tight belts break easily. I haven't ridden a bike with an open chain since 1977 and don't plan going back now - belts are the new chains!
I live a mile down a gravel road hope I don't pick up a stone If I do I will definitely do the conversion, looking for some wood, Knock, knock
Thanks for the info. I don't think I am doing another belt change. This mod is exactly what I was looking for. It is much easier to clean and lube a chain than change these belts. And when a chain breaks you just slide a new one in and off you go.
Have you seen the damage a broken chain can do?! Slide in a new trans, more like, plus a lot of other stuff.....
They're not old like us Gary, but they will learn!
My original belt broke at 119,600 miles last year, and probably was helped along by the swingarm crack that was discovered the same day.
The emergency belt I ran waiting for the new permanent belt to arrive broke on the second day after picking up a rock. ( I live on a 1/4 mile long gravel drive.)
My new carbon fiber belt has been on for 8,000 miles now and should last the life of the bike.
I just did a belt to chain conversion on my 120" Eglide and although I don't have many miles on it yet I'm quite happy with it and it at this point am not looking back. I researched this quite a bit before making the change and couldn't turn up any dissatisfied people who have made the change using quality sprockets and top shelf latest tech chains.
One of the comments earlier in this thread mentioned lube slinging all over the place. That doesn't happen with the current chain lubes on the market. Maybe it's my pipe but I can't hear any chain noise whatsoever. Belt tech has come a long ways but so has chain tech.
I had 60K+ on my belt and I didn't like the thought of being out in the middle of BFE and leaning on this motor and popping a belt. I may eat my words in the future but not at this point.
WOW, some people had some real bad luck with older bikes and chain drives. I guess I just had good luck back in the 60's and 70's. Never don't remember adjusting chains and getting filthy dirty every 500 miles or breaking down along side the road every ride. that's with a 100 k+ miles ridded by 1974. anyway....belts are great and the only chain I would use now is on a original chain bike or on a hi-hp bike on the strip.
I love the belts and don't want to change but I've never had a chain let me down in I don't know how many 100ks of miles. I have however been left in remote places with a broken belt but these were early Primary belt drives. I'm in the middle of a 124 S&S build and am looking at that skinny 20MM belt. Sure would be interesting changing that in BFE. Still debating and wondering if there is a tougher belt of this size out there.
