Rear drive belt?
Old May 9, 2013 | 08:03 PM
Joe2010ultra's Avatar
Joe2010ultra
Default Rear drive belt?
Ok I have just about had it with rear drive belts. Picked up a stone last fall and cut my belt . Changed forward and aft pulleys and belt this past winter. Now here's where the fun starts . 120 miles on new belt picked up another stone. I've just about had it with this belt stuff. Question is has anyone on here ever changed over to a chain drive? Honda and BMW are really starting to look good. I am a jet tech and I'm getting tired of turning wrenches all day and coming home and having to wrench some more on my relaxation toy.
Old May 9, 2013 | 08:31 PM
omaho5's Avatar
omaho5
You must be one of the most unlucky folks around. I've ridden many thousands of miles
and never had this problem. My driveway is a 1200' ft dirt/stone road, too.
If not abused, the belts will go 50K.
Old May 9, 2013 | 08:41 PM
AlaskaAviator's Avatar
AlaskaAviator
Stone hole in the center of the belt is really not a big deal. If it cuts the belt on the edge that may be a different story.
Old May 9, 2013 | 08:46 PM
Retrop's Avatar
Retrop
Do you live on a gravel road by chance?
Old May 9, 2013 | 08:57 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
you can get chain conversion kits.
Old May 9, 2013 | 10:00 PM
Tirpitz's Avatar
Tirpitz
Got 60,947 miles on my 2008 Ultra and the belt should go at least 100.000 miles or more.
Old May 9, 2013 | 10:45 PM
harleytq's Avatar
harleytq
I agree, these belts ain't the greatest, specialy that little skinny belt on my 06 ultra. I got a rock at around 15,000 got lucky to make it home from Colorado to Minnesota. the next time I went to go riding it broke.
Old May 9, 2013 | 11:26 PM
twistedcherokee's Avatar
twistedcherokee
I had a hole from a rock for the past 50K, belt broke @100K. But it was the 1.5" belt. I went with a 1" belt this time so I could run a wider rear tire. I live on a gravel road & have no problem taking gravel roads when I am out riding.
Toby
Old May 10, 2013 | 12:08 AM
mkguitar's Avatar
mkguitar
there are chain conversions.
makes easy for gearing swaps, maybe even a wider wheel if you want.
the belt was to reduce maintenance and to meet noise regs.
my FXRp belt went at about 48 ...and was a CHP bike for the first 40K of it's life.
The FLHTC went to 70K and i changed the belt when doing some other work...so since I was in there I swapped it.
I'm ok with belts... got a 11mm belt primary on the Panhead
mike
Old May 10, 2013 | 01:22 AM
my67pnycar's Avatar
my67pnycar
These belts are made to last a long time. Sounds like you have had some really bad luck. Converting to chain drive seems like backwards progress dont you think? Just sayin..
