Broke down HELP!
Old May 15, 2013 | 07:02 PM
soft 02's Avatar
soft 02
You replaced your bars? Look at the micro switch in the right housing.
Old May 15, 2013 | 07:06 PM
marvo75's Avatar
marvo75
Yea bars were replaced and been riding 2 weeks, just happened today with problems. I put a bad dad rear all in one fender but its all ood. No fuses popping now. Just th front turn signal on left side bright as **** and n rear signal/ Left side wont blink right side will front and back. Whats a micro switch?
Old May 15, 2013 | 07:08 PM
soft 02's Avatar
soft 02
When you apply the front brake its the little switch in the housing that completes the circuit for the brake lights. They are easily damaged when putting levers on.
Old May 15, 2013 | 07:10 PM
marvo75's Avatar
marvo75
You know what i broke my break switch when doing the bar swap and put a tiny screw in the plunger to get me by till the new switch got her. Screw still works breaks good, maybethats the problem?
Old May 15, 2013 | 07:11 PM
soft 02's Avatar
soft 02
Could be. Need to replace it anyways.
Old May 15, 2013 | 07:18 PM
marvo75's Avatar
marvo75
What is the micro sitch? Do you mean the break switch on the bars?
Old May 15, 2013 | 07:38 PM
soft 02's Avatar
soft 02
Yes. It is a micro switch. Sorry. Shoulda been more clear.
Old May 15, 2013 | 07:40 PM
marvo75's Avatar
marvo75
new switch is on still same thing....Bulb is super bright whn i hit turn signal you can see it dim barely
Old May 15, 2013 | 07:45 PM
marvo75's Avatar
marvo75
Man im at a loss...the new bulbs i bought look jut like the old one they say 2057 stop turn tail. These are the right kind yes?
Old May 15, 2013 | 07:51 PM
soft 02's Avatar
soft 02
Back to chasing wires and unplugging stuff till it works.
