Torque wrench ranges
Old Jun 12, 2013 | 06:38 AM
jus2anoyu's Avatar
jus2anoyu
Most of your small fasteners are inch pounds. Cam cover, primary cover, drain plugs, exhaust etc. For light maintenance, inch pounds is a must.
When you start getting into your engine and drive train, you need foot pounds.
Keep in mind, torque wrench accuracy is calculated in percentage. A high quality wrench will be accurate within less than 1%. That means if you set to torque 85# your accuracy will be within less than 1 ft lb. With a cheaper wrench, their accuracy can be off by as much as 10%. So that same 85% could end up being 76# or as much as 94#. Maybe not that critical at 85#, but not something you want to risk when you start talking about a compensator nut, or inch pounds.
Mac10
Mar 4, 2013 06:11 AM
nkauf21
Jul 23, 2010 07:01 PM
upirons
General Topics/Tech Tips
Jun 16, 2009 11:26 PM
Lone Watie
Jan 11, 2008 10:03 AM
eglidebob
Dec 30, 2006 03:11 PM
