So every once in a while my '11 eglide classic will either idle up to around 1200rpm and some times drops below 1000rpm and doesn't run well, having to throttle high to go in first gear. Again, this does not happen very often, but enough to make me go "hmmm!!!"
Talked with an independent mechanic yesterday and he said it is when the engine is getting hot, the computer shuts down the back cylendar. Sometimes the engine light comes on as well.
My '08 would act the same way occasionally. HD tech said it was corrupt data in the ECM. They would have reflashed it to stock but I bought a tuner instead. Never an issue after I installed the SEPST tuner.
So tonight at a stop light the motor idled low enough to stall when trying to take off. Re-started, revved up and go. Problem was when shifting to 2nd gear the engine began to rev really high and got stuck at 3000rpm, luckily I was able to coast into a parking lot.
