Another Handlebar Question
Old May 25, 2013 | 03:36 PM
bberck's Avatar
bberck
Originally Posted by Ultra Pearl
I don't understand this, one person says you have to change clutch cable the other says you don't.... how can you order anything with that advice. confused.
If you want the cable routed the same as stock then a +4 works great on the clutch.
With a little work at rerouting it you can get by with the stock cable.
Old May 25, 2013 | 04:02 PM
dave grider's Avatar
dave grider
What types of bars can be installed on a 08 Ultra without having to change clutch/brake cables and switch cables?
I want about 2" more rise.
I put flanders mimi apes on my street glide and all I had to do was reroute the clutch cable. hope this works for you. Dave
Old May 26, 2013 | 07:41 PM
Ultra Pearl's Avatar
Ultra Pearl
so guys when you say you can reroute, is that inside the faring or outside?
Old May 27, 2013 | 12:54 AM
mike_oh's Avatar
mike_oh
I was just talking to customer service at Wild1 and the guy told me that you need a longer clutch cable(4 over) for the WO575 bars.
I am confused, one person says you do, another says you don't.
Put these on my Ultra. The clutch cable would was not long enough to go back through the hole in the fairing so I am running it outside. It looks okay but when a new cable is needed I will go +4. All the other stuff was fine.
Old May 27, 2013 | 07:09 AM
bberck's Avatar
bberck
Mine still comes out the hole in the fairing, just had to reroute it inside the fairing and move were it mounted to the frame a little.
Old May 27, 2013 | 03:12 PM
pit1600's Avatar
pit1600
same for me. Maybe these pics will help
Old May 27, 2013 | 03:58 PM
prezflyr's Avatar
prezflyr
I just put WO575 on my 09 Ultra and changed the clutch cable just because I wanted it run same as stock around the radio. Really did not need to change anything. Wish I would have done it years ago, what as difference a few inches makes. HA-Ha
Old May 27, 2013 | 08:25 PM
Ultra Pearl
Guys thanks for all the info, just a few more ?'s, when you rerouted, did you have to let the clutch cable go from the clutch handle? or can you reroute without leting it go. I'm a little tentative about having to re adjust cable.
I priced the WO575 from Parts Canada..$288 +tx. Is that a fair price here in Canada.
Old May 27, 2013 | 08:54 PM
bberck's Avatar
bberck
Your going to have to loosen the the clutch and and unhook it from the lever in order to reroute it. Its not a hard thing and something you should learn how to do in my opinion.
Honestly and not trying to be harsh but if your worried about adjusting the clutch I would conside having some one else install the bars. Going to be a lot more more difficult things involved in a bar swap.
That said I have done lots of things I was Leary of. Just make sure you have a manual and take your time and of course lots of people here to help.
Old May 29, 2013 | 08:29 PM
Ultra Pearl
I was just wondering if I had to let it go from the clutch lever, can i just get the slack in the adjuster by the down tube, without having to open up the primary and adjusting the clutch itself, or can i retighten the cable and be good to go.
