Engine guys help please
Old May 23, 2013 | 11:19 AM
nomad billy's Avatar
nomad billy
Default Engine guys help please
changed oil and filter,rode 20miles or so everything fine.Loaded up this morning for 2500 mile trip and oil light came on ,checked and no oil in tank none on the ground just gone.Put another qt. in just in case started it ,shut down now thats gone.Whats going on?I'm at a loss,everything fine then not! Any help muchly appreciated.
Old May 23, 2013 | 11:28 AM
checkers's Avatar
checkers
What model bike??
Old May 23, 2013 | 11:32 AM
brandss's Avatar
brandss
Don't mean to sound stupid but, the filter will suck up some of the oil when first changed. No oil meaning none on the dipstick? I assume the engine or pipes aren't showing oil. Very weird. Will be waiting to here what others say. Sorry I couldn't help
nomad billy
Its an 04 Roadking,excuse that just concerned a bunch.
stro1965's Avatar
stro1965
You might want to check the oil level in your primary.
Old May 23, 2013 | 11:35 AM
AlaskaAviator's Avatar
AlaskaAviator
Could be going in your primary. How many quarts did you put in after oil change? You said the light came on, Road King?
Old May 23, 2013 | 11:38 AM
nomad billy
Nope primed the filter as always and checked before I fired it up,full to the cold mark on kickstand.Fired it up,walked away to let it warm up came back to the light on,3 minutes max,shut it down, checked it again,dry.None anywhere,has to be in the engine,but what happened?
Old May 23, 2013 | 11:39 AM
PistonPuller's Avatar
PistonPuller
Is it smoking when fired up? What color smoke?
Old May 23, 2013 | 11:48 AM
nomad billy
No smoke of any kind.
Old May 23, 2013 | 12:00 PM
checkers's Avatar
checkers
I assume on your RK the oil fills directly into the crankcase and not a "tank". The oil cant be above the pistons, it can pump into the cam area and not allowing to drain back to crankcase, this is unlikey. It's not burning oil or it would smoke, it's not leaking or you would see it. The only place it could be going is in to the primary from thinking thru it or staying up in the camshaft area and not draining down.
