Gas Smell?......
Old Nov 29, 2007 | 06:27 AM
biz44's Avatar
biz44
Default RE: Gas Smell?......
ORIGINAL: Dioglidesx2
There is an externalvent line that attached to the side of the fuel fill. When you park your bike the engine heat radiates to the fuel tank which warms the fuel causing it to expand and push air or fuel vapor out this vent. It ends near the rear of the primary by the frame. I always park mine with a full tank of fuel and sometimes if its just a little too full, some gas will exit through this vent. My RG is an '02 carbureted, but I think all have this vent. If the smell is gone when the engine cools off, this may be where the gas smell is coming from.
You sir are 100% correct.....I am not sure if there is a prize or not though.
I have discovered the same EXACT issue as stated above. The fuel overflow line that goes from the recessed area under the fuel fill cap is where some fuel can poolif the tank was recently
filled all the way up....then when its placed on the side stand it will get into the overflow line.
Or....if the tank is almost full and the engine has been just shut down there may be some venting, and this will also exit via the same line. The reason you smell the fumes more right after parking, is because the bike is now in a confined area, and not riding down the road, and the heat rising directly off the hot engine (and not getting blown to the rear as when your riding)
will cause more venting of fumes.....I think???
Old Nov 29, 2007 | 06:37 AM
Tin Man 1's Avatar
Tin Man 1
All of a sudden when I parked my '07 Ultra Classic in the garage I had a very strong odor of gasoline. A new gas cap cost a little over $20.00. Ask me how I know.
Anyway this is probably too simple, but are you sure you didn't leave the gas cap at the last place you filled up?
Old Nov 29, 2007 | 09:20 AM
StreetGlider56's Avatar
StreetGlider56
ORIGINAL: rickpeg
BINGO!
Old Nov 29, 2007 | 11:20 AM
captjon37's Avatar
captjon37
Its you bikes version of a dutch oven. Try it with that special person in your life an you will see the bond that creates. Enjoy.
Old Nov 29, 2007 | 11:40 AM
bobartz's Avatar
bobartz
i have heard that if you have an injector leaking you will also have a strong smell of fuel. check it out Bob
Old Nov 29, 2007 | 12:16 PM
drodg's Avatar
drodg
My 08 Ultra smells like gas after riding and the engine is fully warmed. It reminds me ofmy muscle cars after I drive them. I have checked the gas cap and its tight. I am about due for my 1K check (snow dependant) so I will have it checked.
chaselee
Nov 30, 2016 12:37 AM
05 Sportster - 1200XL
Jan 29, 2016 11:38 PM
Old Bones
May 19, 2011 07:53 PM
RicksFlhti
Nov 10, 2007 10:28 PM
Crimson
Sep 13, 2005 05:30 AM
