Horn does not work,What fuse powers it?I live wired it and it works looked at Man. No horn labeled fuse that I can see in it,Or did the switch chit the bed and if it did,Do you have to rip all the wiring from the switch all the way down or cut wiring and splice it in?I removed the tank and checked the wires under there all's well,took the handle bar switch apart that looks good,I'm at home fluke meter at the shop(might have to go and get it)wanted to check the basics.just bought the bike over winter did motor work,So I don't know if it worked before,The bike did not get washed yet this year,The bike is a 2009 ultra,15000 miles if that helps
I just got the bike,And I will be buying very soon,Looked at the fuse panel no label for horn checked all looked good but have had bad fuse's that looked good but did not work,So that's why I was asking?So I cound switch it maybe with a different 5,10,15,20 amp fuse.
Thanks again I tapped on the switch (stuck) it works now ,you ever heard about agreat tool called the power probe I use it more than a fluke meter?check it out!! IRONMIKE
