Pro's & Cons Needed
Old May 27, 2013 | 02:25 PM
Enjoyinlife's Avatar
Enjoyinlife
6th Gear
Default Pro's & Cons Needed
Which is better, Vance & Hines Fuel Pak - Screamin Eage Super Tuner - Power Commander. It will be going on 2012 Flhtcu stock with Rinehart 4"please share your knowledge through your experience. Knowledge with out experience not needed. Thanks
Old May 27, 2013 | 02:36 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
not trying to be a smarts *** but... with is better for u only u can decide,with tuners it is always a trade off between cost and functions u think u need or may need in the future.lots of threads on tuners and how they work.
Old May 27, 2013 | 02:38 PM
0ldhippie's Avatar
0ldhippie
Of those options, No question, SE pro super tuner! The PCV many be the best add on tuner (FP is junk) but the SEPST, along with the tts and power vision, actually remaps the ECM. Add a proper dyno tune for the best of all worlds.
Old May 27, 2013 | 02:45 PM
bgdv1's Avatar
bgdv1
im running the SE pro super tuner w/auto tune. working out great for me
Old May 27, 2013 | 02:54 PM
TUCCI's Avatar
TUCCI
Didn't know the SEPST remaps the ECM, thought it did the same thing as the PCV which is alter preset ECM table figures.?
Old May 27, 2013 | 03:12 PM
user 8373900's Avatar
user 8373900
Why not use the power commander Vision. It flashes the ECM same as the HD Race Tuner and uses your stock O2 sensors. It was developed by the same guy that did the SEPST.
Old May 27, 2013 | 03:31 PM
Charlie Fogg's Avatar
Charlie Fogg
My recommendation would be the super tuner with a dyno tune. I have done this with 2 bikes now. 1rst bike had the dealer download and it was worthless. Current bike had the dealer download but I changed to PCV. The tune was just throwing lots of fuel in and heat management seemed to kick in real quick. Did the super tuner with a good dyno tune with great results. Improved MPG, runs cooler, zero decel popping and runs great. About a $300 difference between the PCV and Super Tuner w/ dyno tune.
Old May 27, 2013 | 05:00 PM
Enjoyinlife
6th Gear
Thanks to everyone for their input, I'm leaning towards installing V/H Dresser Duals and SEPST having the dealer install these items helps keep the warrenty in place, at least at that dealer.
Old May 27, 2013 | 05:16 PM
bigdumbnoitall00
make sure your dealer has a competant dyno operator,doesn't really matter with flash tuner u use its all about the #s the tech puts in it.i have seen dyno tunes farther off than any canned map.
Old May 27, 2013 | 05:47 PM
Lowcountry Joe's Avatar
Lowcountry Joe
If all you are doing are the slip-ons, then you don't need to do anything else right now.
If you are going to add an air cleaner, then yes you should probably richen it up a bit or you will be too lean.
I hear what you are saying about warranty and all, but what is the most important...a good tune that you own and you control....or putting it in the hands of a dealer employee that has no real accountability?
There's no question that the Power Vision is the best flash tuner going. I've had a race tuner before and they are simply user unfriendly. Second would be the PC V but it is not a flash tuner and must stay connected between your ECM and the rest of your ignition/fuel system. Thousands in use and they work fine. Again, it's what you value most....warranty or control.
You are probably going to spend about the same amount of money either way.
