Kill switch question?
Old May 29, 2013 | 04:24 AM
wndchsr2's Avatar
wndchsr2
Originally Posted by NDBadlands4-2
I may be the odd one, but I never use the kill switch. Never have. No reason, just don't.
No your not the odd one, well maybe you are and I just dont know......LOL
Havent used the kill switch in years.
Old May 29, 2013 | 05:30 AM
hogcowboy's Avatar
hogcowboy
I have never used a kill switch in 45+ years of riding. Don't even know "exactly" where it is. However, on my wife's Can-Am Spyder it is highly suggested you use it and strange things do happen if you don't. Like losing some preset settings on radio/cb.
Old May 29, 2013 | 05:34 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Way back in the time of dinosaurs, when I started riding, I discovered I personally like using the kill switch to shut down a bike because I have both my hands securely on the handlebars. Just lets me hold everything steady for the final shut down and setting the bike onto the kick stand.
Not that I can't simply use the switch or key (depends on the bike), and sometimes I do. Just that overall, Flicking the engine off with my thumb is preferable, to me.
I'll also tend to leave the bike parked with the kill switch off. In the vague hopes that it would give a thief or foolish person just a wee bit more difficulty.
Old May 29, 2013 | 05:51 AM
RK Joy's Avatar
RK Joy
I have always used the kill switch first, then ignition switch.
Old May 29, 2013 | 06:00 AM
Rdgray's Avatar
Rdgray
99% of time use ignition switch. I have that idle problem. I keep telling myself I'm going to use kill switch but just can get in the habit of doing it. Going for ride today with a guy I built a house for I'll try using the kill switch.
Old May 29, 2013 | 06:18 AM
47Norton's Avatar
47Norton
I think one reason to use it is so you will remember you have one. If you never use it and it gets bumped off accidentally it could cause an embarrassing problem. Seen it happen, done it.
Old May 29, 2013 | 06:24 AM
ShatteredSoul's Avatar
ShatteredSoul
I've never used the kill switch.
Old May 29, 2013 | 07:14 AM
0ldhippie's Avatar
0ldhippie
I only use it when I'm parking on a hill in gear and need both hands on the clutch and brake. I'm lazy and don't understand shutting it off twice??? Less key stokes with just the ignition.
Old May 29, 2013 | 07:20 AM
uklauren's Avatar
uklauren
Florida Crew Moderator
If you use the ignition switch first then the kill switch you won't accidentally leave your lights on and find a dead battery next morning. I usually shut the bike down using the ignition switch.
Old May 29, 2013 | 07:24 AM
Pete6114's Avatar
Pete6114
I don't bother with the KS. Don't see any point in using it.
