LED turn signals
Old May 30, 2013 | 05:10 PM
Ultra89Rider's Avatar
Ultra89Rider
Originally Posted by Keithhu
Wait - are you saying I can just replace the bulb on a stock tail light with a 3158 LED bulb from CD?
That would be killer!
Got a link to the part? Cant find it on CDs web site
I didn't get my 3157 LED bulb from CD. I ordered it on line from superbrightleds.com. They have all kinds of LED lights. Here is a link for different types of 3157 LED bulbs. I bought number 2, and in red (the dual intensity 18 led bulb). It costs only $17.95. The light put out is great and plugs in the stock socket.
Old May 30, 2013 | 05:12 PM
Keithhu's Avatar
Keithhu
Thanks so much! This saved me about $120 by not buying a whole LED tail light unit.
Odd because I searched on superbrightleds.com for 3157 and didnt find anything.
I'm guessing it wont be as bright as the full CD LED tail light unit, but it has to be brighter than stock.
Old May 30, 2013 | 05:31 PM
CGLTD's Avatar
CGLTD
Originally Posted by TexFF
Are there any out there as good as CD but cheaper? $70 for 2 turn signals is tough to swallow.
Really? Have you seen what Harley sells theirs for?
Old May 30, 2013 | 05:59 PM
basselope's Avatar
basselope
I went with all Custom Dynamics. I believe any of the main brands you'll find discussed here at HDF can be good choices, I just decided to buy from a single vendor to avoid potential technical incompatibilities.
Here is the writeup I created for my shopping and installation experiences:
https://www.hdforums.com/forum/touri...2012-flhx.html
Old May 30, 2013 | 06:07 PM
VTL nut's Avatar
VTL nut
As good, NO, cheaper, YES.
I went through $100 worth of junk before spending on the Custom Dynamics.
I bought a few different makes through Dennis Kirk clearance before "seeing the light"............
Bite the bullet, spend the $$, love em and move onto your next endevour.
Old May 31, 2013 | 01:50 PM
HD Rider 2013's Avatar
HD Rider 2013
Stage II
My two cents: CDI is best in class! You will need an equalizer, as the lower current draw of LEDs will otherwise be interpreted by your bike's flasher as a burned out lamp, and will cause the signals to blink fast.
I know there are internet methods to get around buying an equalizer by building a resistor network, but it has to fit in the signal housing, it gets very hot, and is subject to shorting or grounding due to the size of the resistors (size is driven by wattage, and you need some big resistors). I have them, and they are super bright. I followed my brother home on his ride from the dealer and was sold the first time he stopped.
Biggest thing to remember in avoiding a rear-end collision is visibility. Anything you can do to make yourself more noticeable during braking or stopping is great. Even better when you don't have to cluster-f*ck the rear of your bike with extra lamps. Although they are visible, I don't need the back of my bagger looking like Mad Max's car or flashing like a disco.
Good Luck!
Old May 31, 2013 | 02:59 PM
Bushy's Avatar
Bushy
Led in front and rear, LED truck light phase 7 and passing lamps,, less draw and boy are they bright!!!! signals are HD by the way, gifts... still a great thing!!
Old May 31, 2013 | 03:11 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
One more vote for Custom Dynamics. Great customer service. And it took a couple of minutes per light to install. 48 lights of LED brightness. VERY happy with them.
Old May 31, 2013 | 03:27 PM
cvfd17's Avatar
cvfd17
Originally Posted by pkg4vikes
+1 on the Custom Dynamics. I went with their package that had both front and rear LED lights, load equalizer and modulator (for changing brake light sequencing) and love 'em! Everybody that I ride with says they can see me much better.
Same here.....best money spent on bike so far
Old Jun 2, 2013 | 12:56 PM
geopac's Avatar
geopac
Another plus 1 for Custom Dynamics. Just installed the Dynamic Ringzs in the front that match my trucklite and Dynamic Clustrers in the back that work as run, turn, brake with Red and Amber colours. Great Customer Service as they will walk you through your set up and help you customize. I was going to go with Badlands equalizer but so impressed with CD`s customer service that I went with theirs and it was an easy install.
RicMF
Nov 16, 2014 06:58 AM
scott6610
Apr 13, 2014 10:55 AM
jeffsizemore
Jun 7, 2012 11:17 AM
HDV-GLIDE
Jan 26, 2011 03:53 PM
dspencer
Oct 12, 2010 09:17 AM
