Has anyone out there put the new LED harley turn signals on their bikes? I have been thinking about buying them but want some input first. The fron wires look like they are under the fairing. Do the stock signals come with plugs on them so that the new ones can plug into the plug from the old signal? Are you guys happy with these turn signals if you have the LED ones?
I put the Kuryakyn LED's on my '10 SG and made a big difference. But the SG rear lighting is minimal to start with. They were plug & play and an easy upgrade.
Has anyone out there put the new LED harley turn signals on their bikes? YES I have been thinking about buying them but want some input first. The fron wires look like they are under the fairing. Do the stock signals come with plugs on them so that the new ones can plug into the plug from the old signal? YES Are you guys happy with these turn signals if you have the LED ones? YES
Just follow the included instructions. I put H-D LED signals front and back.
I have the Harley Rear turns and a bright *** brake light. easy install. the LED will light up the night, there is no doubt that you are stopping. You can also wire so the turns are running lights too. (this is what i did). I like them! getting the front turns soon.
I only put the H-D LED turn signals/running/brake lights and LED tail light on the rear so far, but it was the first mod I did to my RKC and the most important safety improvement you can make in my mind. One of the advantages of the H-D LEDs is that they are plug and play and do NOT require a load equalizer as many of the lights from other manufacturers do. They are a very easy install.
I borrowed this photo from another forum member (and then added the captions). You can see how much more visible the LED's are than the stock lights, even though the bike with the stock lights is much closer to the camera.
I put Kuryakyn yellow LED turn signals on the front and Kuryakyn smoke color LED turn signals on the back of my Road King and have a bright *** brake light, it makes a big difference. So there should no excuses for not seeing me, however there will always a dumb *** out there trying to prove me wrong......
