Little electrical help needed
Old May 30, 2013 | 01:40 PM
RonS0921's Avatar
RonS0921
Default Little electrical help needed
Hi all, am seeking some or all of your knowledge on what I want to do.
So my knowledge on electrical is not great and don't want to risk burning up the bike, but I purchased a small/cheap radio system for my 97 Road King. The wires aren't long enough to actually reach the battery from the handlebars (handlebar mounted radio only). And TBH not sure I want to run directly to battery after my last little excursion I tried.
Soo anyhow, the wiring that is on this tiny little radio has 3 leads: 1 black(neg), 1 yellow (hot-pos) and 1 red that says to hook up to ignition switch. The black and yellow are on a white 2 prong clip plug which I will probably have to do away with.
I was thinking of running these wires into the headlight to hook up to the accessory switch. Is this a good idea? And what wires inside the headlight would I hook them up too?
Heck I haven't even looked to see how to open the headlight up yet, but figured I would get some insight on my situation beforehand.
Your help would be greatly appreciated and fyi I did do a search on here and didn't find much info on the 5 out of 10 pages I had read as most post were for 03's and up and had fairings.
Thank you much in advance.
Old May 30, 2013 | 01:42 PM
mkguitar's Avatar
mkguitar
well.
on your '97 the power for the light runs through the ignition switch- if you have a fault there--- the bike dies.( so not a good idea to put in a high wattage bulb*)
If the switch burns up, replacement is expensive.
adding your own stuff to the equation increases the load...and the possibility of a fault.
so maybe incurring an expensive fix in the future
I would run the yellow wire to the battery...with a fuse in line at the battery end ( this is for the radio memory) put the wire inside a plastic tubing "sleeve" and run it under the gas tank.
I would get the power at the accessory switch on the back on the headlight nacelle- put a fuse inline.
and attach the ground to existing ground wires, tight and secure.
counter-intuitive, but soldered connections do not hold up on a bike.
use a quality crimp type connector where ever required
mike
* unless you pull fused power from the battery and use relays
Old May 30, 2013 | 02:23 PM
RonS0921's Avatar
RonS0921
Mike,
Thanks for your prompt and very informative reply.
Both the red and yellow wires already have the fuses attached which is a good thing. I will give this a go once I find some more wire to add on to what is on the radio. The wires barely make it half way down the tank so adding more to reach the battery is a must, LOL. I do have crimpers and crimping connectors. Will look in Home Depot or an Auto Parts store for the rubber tubing as well.
Again thank you for your help and the information provided.
Old May 30, 2013 | 03:04 PM
mkguitar's Avatar
mkguitar
stranded wire...not solid core ( resists breaking/ vibrations).
16 or 18 awg gauge should be fine.
tubing: i get at electronic shop-- even double up on heat shrink tubing. it is to help resist chafing/rub through on bike
Mike
Old May 30, 2013 | 04:35 PM
RonS0921's Avatar
RonS0921
Mike
Yup the wire that is on the radio is 18 gauge so I am going to get same size and stranded wire. Never liked the solid core wire crap. Yeah I made a list of what to get and the heat shrink tubing is definitely on there.
Again thanks for the help. Off to the store to get supplies and then figure out how to get to the Accessory switch hookup. All new to me, LOL.
Pyrotag
Apr 17, 2014 12:56 AM
modelflyered
Jul 20, 2013 09:33 AM
MattInFla
Dec 22, 2009 11:01 AM
dolfan
May 15, 2006 01:59 PM
scott
Oct 18, 2005 10:57 PM
