Help - Radio Interference
Old May 31, 2013 | 07:42 PM
jimjudi's Avatar
jimjudi
4th Gear
Default LED Lights
Originally Posted by Lowcountry Joe
LED light circuits can cause broad band emi. Either unplug or un-fuse your light and see if the emi goes away.
Thanks Joe, the LED lights are not head or tail lights, they are accent lights to light up the motor & trans. Disconnected them and still have the noise problem.
Old May 31, 2013 | 07:54 PM
jimjudi's Avatar
jimjudi
4th Gear
Thanks for all the suggestions. Haven't solved it yet. Cass - the noise is present as soon as the ignition is turned on. It doesn't matter if the motor is running or if the switch is in accessory position. The sound level of the noise is constant - doesn't change with motor running or off, in any ignition position. Noise is not affected when the run switch is on or off, and doesn't make any different noise pattern with turn signals. Just a constant noise when the ignition is in any position except off. There is about a 1 second delay when the ignition is activated, almost like something is being energized then the noise starts. That's why I'm suspecting the FuelPak but that is just a guess. Tomorrow is going to be a rainy day, I'll disconnect the fuelpak and see if makes a difference. I'm also thinking of adding a noise filter in the power line feeding the radio but don't really want to start hacking wires on a relatively new bike.
Old May 31, 2013 | 07:58 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Fuel Pak should not be causing the issues your encountering, the ECM has nothing to do with your radio and/or lights power supply. Is the radio noise/static free when playing without plugging in the mic/intercom? If so, your issue is in the mic/intercom wiring....if not, I'm at a lose also....
Old May 31, 2013 | 08:58 PM
whetsel.m's Avatar
whetsel.m
Radio Shack, Ferrite Choke. Wprked for me.
Old Jun 2, 2013 | 01:31 PM
jimjudi's Avatar
jimjudi
4th Gear
Problem Solved - with another mystery. THere's a Y harness under the seat that was the culprit. Not sure what it is for but seems to possibly be a sealed resister with 8 wires in and 8 wires out. The quick connectors have a label AMP over a slot between possitions 2 and 3. The sealed box is stamped 4412 - no other markings. 3 dealers couldn't find this on 3 different service appointments. Found it in 10 mins the old fashion way - disconnecting harness connectors. Thanks everyone for all the hints and suggestions. Now back to HF to find out what this nysterious y connector really is and what it's for.
Old Jun 3, 2013 | 08:20 PM
jimjudi's Avatar
jimjudi
4th Gear
Answer - if the rear turn signal / running light kit is installed, the module that creates the pulse to turn the turn signals into running lights+brake lights causes the interference in the audio circut. HD's answer is to remove the running light kit and in there opinion problem solved. I said what about the $$ spent for the HD accessory and ther fact that it is a HD kit made for my model. They said live with the noise or remove the kit. Not happy with the answer but at least I know the cause.
Old Jun 4, 2013 | 02:20 AM
my67pnycar's Avatar
my67pnycar
I have the run/turn/brake module on mine, no problems so far (knocking on wood) you think you could of got a bad module???
Old Jun 4, 2013 | 06:11 AM
Ride my Seesaw's Avatar
Ride my Seesaw
You DO have recourse if the module is radiating interference. I would call MOCO and tell them their product is not in compliance with the FCC's rules on 'Unintentional Radiators.' The Feds have very strict regulations about marketing products that interfere with radio, tv, and communications, etc. A product not designed to intentionally radiate a signal, but does so anyway by virtue of its on board clocks, oscillators or microprocessors is subject to meeting stringent testing and compliance requirements under part 15, subpart B of the FCC's rules and regulations. If it's radiating noise that blocks your radio reception, it's illegal in the eyes of the FCC. If you look at the back of most electronics there should be a little sticker on it that says 'It's in compliance with FCC part 15'. If your module doesn't have this sticker then a friendly reminder to MOCO that their product has never been sent for compliance testing, or it wouldn't be radiating interference, so your next communication will be a letter of complaint to the FCC.
http://en.wikipedia.org/wiki/Title_47_CFR_Part_15
Old Jun 4, 2013 | 07:24 AM
fjm3rd's Avatar
fjm3rd
I have a 12 SG with LED accent Lights have no interference with radio. But installed the Custom Dynamics LED turn signals kit a few weeks ago. Now when the signals blink I get the static only in the radio when it is on FM. AM seems ok as far as I can tell. Any ideas how to fix it.
Old Jul 20, 2013 | 06:34 PM
zeppelin316's Avatar
zeppelin316
same problem here. Harley boom power ant. static with blinkers only
