Dealer Techs-Never Know What You Will Get...
Old Jun 1, 2013 | 02:54 PM
5TIME's Avatar
5TIME
Default Dealer Techs-Never Know What You Will Get...
I just changed all three fluids on my 2012 FLHX. I allowed the dealer to to the 1,000 mile service, and then planned to service the bike for the rest of my ownership myself. As a backdrop, I am extremely **** retentive, and service all of my own vehicles. Anyway, I found some things that were both wierd and counter to what one normally finds when servicing a vehicle after a dealer has serviced it. To begin, all three plugs had a sort of "pipe dope" on them. I'd understand pipe dope if I was screwing together galvanized plumbing, but what the heck is this on drain plugs? I cleaned all three "whistle clean", put on new "o" rings and installed after draining each respective fluid. What was also weird is that all three were just past "hand tight". Normally, techs way overtighten things in my experience. These were so lightly tightened, I would have thought they would leak...but I guess not with that pipe dope stuff. Anyway, I'm glad I have my preferred fluids in the bike now. Has anyone seen this pipe dope stuff used on any kind of drain plug? I've rebuilt two engines, and have done all of my own service for 30+ years; this is a new one on me...
Old Jun 1, 2013 | 03:21 PM
karbar99's Avatar
karbar99
The dope isn't necessary but I've seen and heard many do this just as I've done in the past.
Old Jun 1, 2013 | 03:42 PM
rooti's Avatar
rooti
If you are **** retentive then you will never bring your bike to anyone again. Everytime I got it back from harley I was so mad I wanted to hurt someone. (and that was only twice...one for free service and once for warranty)
Old Jun 1, 2013 | 03:44 PM
5TIME's Avatar
5TIME
Absolutely true, I won't take it anywhere. I let them do the 1,000 mile because it was free and I also had them do the dyno with my Stage 1 at the time.
Old Jun 1, 2013 | 03:45 PM
B00001's Avatar
B00001
I am with ya there. I had an '09 I picked up used so first thing I do is change all fluids, etc. I had the same pipe dope crap on mine. I was looking at the drain plugs just sayin WTF??? Ha! Same as you, cleaned them up, new o rings, torqued to spec and all good ever since.
jus2anoyu's Avatar
jus2anoyu
The pipe dope is a good idea when you install different metals together. The engine is aluminum, and the plug is a steel alloy. The dope will keep the two from having a chemical reaction with each other seizing them together
Old Jun 1, 2013 | 03:47 PM
5TIME's Avatar
5TIME
Is this the same pipe dope that I have used on plumbing? Please tell me that it isn't and that it is some automotive-specific stuff that I haven't (surprisingly-if it exists) seen.
Old Jun 1, 2013 | 04:08 PM
jus2anoyu's Avatar
jus2anoyu
Yes, it's an automotive specific compound. Mine is made by permatex.
Old Jun 1, 2013 | 04:18 PM
ynots's Avatar
ynots
My bike had pipe dope (teflon?) on the plugs when it left the factory. Cleaned it off during the first self oil change and haven't had any leaks doing without.
Old Jun 1, 2013 | 04:25 PM
Junkster's Avatar
Junkster
Loctite makes it. Come in a roll out stick.
