Powervision Autotune basic...how long do you run it?
Old Jun 5, 2013 | 08:05 AM
56tbird's Avatar
56tbird
Default Powervision Autotune basic...how long do you run it?
I put on a new set of CFR slip-ons, loaded a Fuel-Moto map for it and would like to dial it in with the autotune on my powervision. I haven't run autotune before, so I would like to know how long in miles (or time) do I need to run it in order to get enough numbers for a good map?
Old Jun 5, 2013 | 09:14 AM
Deckman's Avatar
Deckman
You can run it for 5 minutes or more after the "warm up" leaves the display. You will have to do multiple runs to get a decent tune in the Basic mode. I typically run up to about 15 minutes.
Old Jun 5, 2013 | 09:48 AM
XARAN's Avatar
XARAN
Warn the bike up then start data loging and take it out for a ride. 15 -20 minutes at all of the various speeds, loads and conditions that you can throw at it. You can see the cells populating you want as much data as possible. make a few data runs until you are within 5% change
Old Jun 5, 2013 | 12:47 PM
pontiac69's Avatar
pontiac69
how do you know what percentage you are within? is it here (see pic). i just made another auto tune run and it says 1% max- 9%
Attached Thumbnails Powervision Autotune basic...how long do you run it?-0605031551.jpg
trike1
The Dyno Room
Aug 3, 2019 06:11 PM
IrateCitizen
2014-2024 Touring Models
27
Sep 24, 2014 08:45 AM
rsking45
Jul 25, 2014 08:22 PM
PistolPete83
Jun 4, 2013 03:22 PM
2manytoys
May 23, 2013 08:59 PM
