if i have a long distance to get stopped i usually let the bike slow itssfelf doen and down shift as it does with very little brake. ither wise i use brakes and shift the gears as i slow to be able to take off if needed. i dont think either way is bad for the bike..
JMO
the brakes are made to slow you down- use them
the gears are meant to be shifted- so shift lol
A combination of both, used right is whats' being promoted...
You downshift to maintain a reasonably useable RPM range. You use brakes to stop.
Many find it immeasurably easier to replace brake pads than piston rings.
Dropping gears as you slow down is best and keeps you in complete control of the motorcycle and is easier on the transmission and brakes. Always be in the right gear for the speed your going just in case you need to get out of the way in a hurry.
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
I once read a study saying that general brake wear cost less than the additional fuel burnt while over revving (down shifting). Coming to a stop with this 6 speed gearbox I usually get an RPM increase of 300 revs between gears; I'm not beating it for free.
Originally Posted by beary
I'm not sure how that works since fuel flow rate is dependent of the right hand, not engine RPM?
Beary
Each revolution of the crankshaft draws fuel, I don't think we have an injection dwell feature to starve the engine until it reaches a lower 'targeted' speed ?
Hmm, OK. Your orginal post makes sense then. Still for me, I like having the additional control using the engine for drag and power to control speed. It's worth the extra cost in fuel.
