Down shift or brake?
Old Jun 5, 2013 | 03:05 PM
ftworthcowboy's Avatar
ftworthcowboy
Originally Posted by nchogfan
Like you, I use both brakes but usually start with the fronts. I downshift as I'm braking when my RPM's get low and are a good match for the next gear instead of downshifting all the gears at once.
This what I do also.
Old Jun 5, 2013 | 03:14 PM
beary's Avatar
beary
Originally Posted by brownfoxx1
use the brakes to stop. brake pads are WAAAAAYYYY cheaper than trans parts.
I've driven over a dozen cars and bikes in my lifeitme using the engine for braking, several of those cars had over 200,000 miles. I presently drive a corvette as a daily driver and consider my style of driving a bit more sporty than the average driver. Not only have I never broke a transmission, I have never replaced a burned out clutch either. Most importantly downshifting is a safer style of driving.
Beary
Old Jun 5, 2013 | 03:26 PM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Originally Posted by beary
Hmm, OK. Your orginal post makes sense then. Still for me, I like having the additional control using the engine for drag and power to control speed. It's worth the extra cost in fuel.
Beary
It seems double clutching is 'the' bad habit that can reduce mileage by 10% in city traffic and it also affects the duration of engine braking. Going down mountain roads is a different story, I never let the engine go below 2,000 rpm because of gravel and uneven pavement (if any).
Old Jun 5, 2013 | 03:36 PM
DHubbs's Avatar
DHubbs
Soooo,,,,,,,, nobody just drags there feet????
Old Jun 5, 2013 | 04:14 PM
Rdgray's Avatar
Rdgray
To me downshifting will always give you better control. Just like riding the twisties downshift approaching a turn and accelerate coming out of it.
Old Jun 5, 2013 | 04:17 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
I use both of my brakes, since that's what they're there for.
Old Jun 5, 2013 | 04:33 PM
Bpf's Avatar
Bpf
I'm not sure how that works since fuel flow rate is dependent of the right hand, not engine RPM?
Beary
As far as I know, engine braking uses nearly no fuel since because the air intake is nearly closed, the ECU makes the injectors to send only the smallest possible amount of fuel.
From what I've understood of engine braking, the engine brakes because of the vacuum created by the lack of air at the intake and I guess that is why engine braking can be noisy since the flow of air is troubled and is probably at a pressure lower than the ambient pressure. (I don't know what happens exactly in the exhaust)
But the oil pump continues to run and lub, and the amount of detonated fuel is low so the stress on the piston/cylinder should be lower than when running at the same RPM in 'normal condition' (going forward by burning fuel).
Also when braking with the engine, the load on the teeth of the gears is on the opposite side of the normal condition : if some gear fails it won't be because of engine braking but because of the wear of normal use. (unless you go into the RPM red zone)
Downshifting also helps keeping the brakes at a reasonable temp and is mandatory when riding/driving over mountains.
Years ago I had two clutch rebuilds on two BMW (bikes), but at the expected mileage (at about 70K km: the mechanic told me in both cases that this was a 'normal' mileage for a clutch rebuild ). I rode the first bike mainly in flat areas, the other mainly in mountainous areas and had to use a lot more engine braking/downshifting than on the first one. And I never had any engine problem (piston/segment/etc).
Dragcity's Avatar
Dragcity
Downshift
Old Jun 5, 2013 | 05:08 PM
Ben221's Avatar
Ben221
My hands and feet do this on their own, let off gas, start braking front and rear, then clutch, down shift accordingly until a stop in neutral usually with letting off the rear brake at almost stop to put my foot down.
Bikes are like a helicopter, need all your extremities to operate.
Old Jun 5, 2013 | 05:47 PM
2011FLHTK's Avatar
2011FLHTK
I'm 80% engine and 20% brakes so the guy behind me knows I'm stopping.
