Ipod
Old Jun 7, 2013 | 08:57 PM
Geoff's Avatar
Geoff
Connect iPod to stereo aux input via cable. Set the stereo to Aux; and then turn on the IPod and start your music. Be sure to turn up the volume on both iPod and stereo.
Old Jun 7, 2013 | 10:30 PM
SPECIAL ED's Avatar
SPECIAL ED
I wish somebody would explain to me how to make one of those MP3 CDs. I tried using Windows media Player with no luck the CD player didn't recognize it.I only used Media Player because I was told I tunes wouldn't work.
Old Jun 7, 2013 | 10:42 PM
rvnkontum's Avatar
rvnkontum
Originally Posted by SPECIAL ED
To say you can't control it with the stock stereo controls is not completely accurate.You can't select play lists or turn it on or off.You can turn it up and down and adjust bass/ treble, fade etc.I usually just start my ipod on shuffle or a good long playlist and go.
If this is true, then this is all O all need. Thanks!
Old Jun 7, 2013 | 11:55 PM
Munkee's Avatar
Munkee
I personally tried 3 different 3.5 mm cables and none worked. I had to jiggle all of them to get them to play and it got old. I since researched and found this.
http://blog.ironacesspeedshop.com/ho...vidson-stereo/
I used the Isimple is75 cable from Amazon for $14 in like new condition and it charges my iPod while I play it. No more hassle to with 3.5 mm cable. Sure I can't change playlist thru head unit but I can still control volume thru handle bar controls. Its all I needed. I mounted it on bars close to fairing and I can forward songs fairly easily. Its a no brainer to not have to deal with seperate volume on iPod and HU. And its cheap.
Old Jun 8, 2013 | 12:10 AM
my67pnycar's Avatar
my67pnycar
Special Ed, start off with mp3 formated music from your computer. Put what you want to burn in the libary of windows media (left click,hold,drag-n-drop). Highlight what you are going to burn to cd (point mouse on first song, left click, hold shift down/ arrow down at the same time, this will highlight a bunch at once, right click, select copy, left click mouse in destination folder, right click again, select paste this will copy all of the songs you just highlighted to that folder/cd. Media player will ask you how you want to burn it, select DATA. It will let you know when the cd is full. Insert in your HK, sit back and enjoy 130+ songs on 1 cd. Hours and hours of music that you can utilize your handlebar controls with. If I am wrong on any of these steps someone will correct my dumbazz, lol. Good luck
Old Jun 8, 2013 | 02:07 AM
davessworks's Avatar
davessworks
Sounds right.
Old Jun 8, 2013 | 03:17 AM
nightster36's Avatar
nightster36
I have installed the iPod interface from http://ironcrossaudio.com/ipod-harleydavidsonradio.html
$250 is not bad for being able to control the iPod completely through the hand controls.
Old Jun 8, 2013 | 07:42 AM
SanJuanRon's Avatar
SanJuanRon
I added a small Bluetooth device ($20 online) that synchs with your I Phone (not I Pod) and let's you play music without any cords. Sweet! SJ Ron
Old Jun 8, 2013 | 09:13 AM
lionsm13's Avatar
lionsm13
I use a griffin Ipod case for my 120 GB Ipod(currently 5900 songs) and have velcro attached to it and run the other part of the velcro on top of the brake fluid resivoir and run an Ipod dock/cable 3.5 plug to the H/K outlet. Been using it this way since the bike was new, almost 4 years ago, no issues.
Screw CD's.. no thanx.
Old Jun 8, 2013 | 02:32 PM
rvnkontum's Avatar
rvnkontum
Originally Posted by CGP93
Aux jack front lower right hand corner. Buy a aux iPod cable from RadioShack $4. And youre good to go!
Bought the 3.5mm cable at Radio Shack, $13, put the IPOD in one of the windshield pouches, ran the wire to the aux plug, music! Works great!
