Bag reflecters
Old Jun 10, 2013 | 05:42 AM
vegashd's Avatar
vegashd
Originally Posted by davessworks
Anyhow - this stuff (my previous post) is what all the auto collision repair places use for removing decals, emblems etc. It works very well without damaging anything else.
I'm not aware of manufactures recommending a liquid remover but they do recommend 3m dry eraser wheel.
Either way it works. If I use a liquid I just use wd40
Old Jun 10, 2013 | 05:55 AM
FLHR09's Avatar
FLHR09
3M adhesive remover – plus one. Using it for years and still the best, but getting harder to purchase (EPA).
Old Jun 10, 2013 | 06:13 AM
vegashd's Avatar
vegashd
Blows my mind (although it shouldn't) how all the good stuff is becoming extinct!! The good wd40 formula is gone among other great things!!
Old Jun 10, 2013 | 07:19 AM
Pioneer74's Avatar
Pioneer74
Screwdriver and Goo Gone.
Old Jun 10, 2013 | 07:52 AM
ZenGlide's Avatar
ZenGlide
I considered removing mine, but decided they might look better painted. It seems like it would be fairly easy to pull the entire latch cover off, tape off around the reflector, and just spray paint the reflector. Since my bike is black, the reflector painted black would just look like an insert that matches the rest of the bike.
Old Jun 10, 2013 | 08:34 AM
Stew Pidaso's Avatar
Stew Pidaso
Originally Posted by Toofat
Use a srewdriver with a rag underneath it to protect cover and pry off reflector. Reflector is held on with double sided tape.
+1
Only remove latch from bag and heat from the back side with a heat hun or blowdryer. The heat helps the sticky tape release and by heating the backside the metal transfers the heat better. Just dont ding your paint
Old Jun 10, 2013 | 10:00 AM
davessworks's Avatar
davessworks
Just looked up the wheel thing. Interesting. Have to pick one up. The liquid is good because you can apply it to the object you are trying o remove. For instance, the reflector in question. I'd set the bag on its side (because I found) and pour a small quantity of the solution around the edges then wait for a couple of minutes and pry up. The fluid tends to break down the adhesive in place.
harleyiron80
Feb 26, 2011 09:12 PM
bkbob08
Jan 30, 2009 06:56 PM
youngrider
Feb 20, 2008 06:34 AM
BadBobOk
Nov 17, 2007 12:52 AM
Red Road King
Feb 18, 2007 01:29 PM
