Truck Lite Phase 7
Old Jun 11, 2013 | 08:25 AM
FXDWG12's Avatar
FXDWG12
Just a couple of thoughts. Relocate the ground to your Head Unit. Sometimes the ground wire can pick up the noise if its grounded in a location close to the ground of the noise making devices. Try to maintain a good seperation between speaker / antenna wires and power wires. Noise can be induced onto speaker wires if the run parallel to power wires. Try to overlap these wires at 90* angles.
Old Jun 11, 2013 | 09:08 AM
Pioneer74's Avatar
Pioneer74
Don't know what you guys are talking about, but I have the Phase 7 headlight with Kuryakyn and HD running/brake LED lights, and have had no problems with my FM reception until I put the Soundstream amp in my fairing.
This winter in getting rid of that amp. More problems than it's worth.
Old Jun 11, 2013 | 09:18 AM
HDV-GLIDE's Avatar
HDV-GLIDE
I have a Biketronic Amp but the issue started after the LED Headlight install.....What I may do is disconnect the inner fairing antenna and just use the rear mast and see what happens.....
Old Jun 11, 2013 | 09:26 AM
mp535th's Avatar
mp535th
No problems here. I have the phase 7, LED turns front and rear as well as LED tail light....
Old Jun 11, 2013 | 09:33 AM
Pioneer74's Avatar
Pioneer74
Is your faring antenna electronically amplified?
Old Jun 11, 2013 | 09:37 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Nope, sticks to the inner fairing ( no electronic box) and the plug goes into the radio, so I don't think it will make a difference but I'll try unplugging it anyway......Use ACC position on switch, no interference, go to Ignition with LED light on, it starts....It's the light!!!!
Old Jun 11, 2013 | 09:40 AM
Pioneer74's Avatar
Pioneer74
Stock radio or aftermarket?
Old Jun 11, 2013 | 09:43 AM
HDV-GLIDE's Avatar
HDV-GLIDE
stock radio.......thank god for satellite radio......
Old Jun 11, 2013 | 09:51 AM
Pioneer74's Avatar
Pioneer74
Interesting. Stock radio here too, and I only started having problems after installing a class D amp.
Old Jun 11, 2013 | 10:57 AM
roaddr's Avatar
roaddr
Yep, mine is the same way.
