Truck Lite Phase 7
Old Jun 11, 2013 | 12:00 PM
SBates08's Avatar
SBates08
Originally Posted by Pioneer74
Interesting. Stock radio here too, and I only started having problems after installing a class D amp.
Class D amps are known for FM reception problems. You can read all about it in the Audio section. Or better yet, consult Mr. UltraNutz. I'm sure he could help.
Old Jun 11, 2013 | 12:17 PM
Pioneer74's Avatar
Pioneer74
I know all about class D amps and where the audio section is, thanks. I don't need/want his "help".
Old Jun 11, 2013 | 01:56 PM
SBates08's Avatar
SBates08
Just trying to helpful sir.
Old Jun 11, 2013 | 08:41 PM
09B29's Avatar
09B29
Stock Radio
Alpine KTP amp
Polk MM 651s
Original antenna on back
Truck Lite 7 LED Hedlight
No problems
Old Jun 11, 2013 | 08:55 PM
bobgv's Avatar
bobgv
Lighten up Francis! The guy is just trying to help. If you didn't want any input or help don't post on the forums.
Old Jun 11, 2013 | 09:01 PM
bobgv's Avatar
bobgv
I am having reception problems and interference when I use my directionals. Receptions goes in and out as the light blinks. I have the phase 7 light CD LEDs all around with biketronics load equalizer. So will follow this thread and any help with fixes are more than welcome here.
Old Jun 11, 2013 | 10:01 PM
SBates08's Avatar
SBates08
Some folks seem to get their panties wadded really easy. This place is chock full of useful knowledge for those of us who don't know it all.
Old Jun 12, 2013 | 07:00 AM
Pioneer74's Avatar
Pioneer74
Never said I knew it all. Far from it. Learned a lot from this site, and still do everyday. If I came off that way in my response, I apologize.
Old Jun 12, 2013 | 08:01 AM
SBates08's Avatar
SBates08
No apology needed. Maybe I took it the wrong way.
Old Jun 12, 2013 | 08:30 AM
Elqueso2's Avatar
Elqueso2
I had the same problem with a pair of LED running lights I added to the bike. Turned them on and instantly wiped out my FM & Weather on my stock radio and antenna. It was so bad that is was bleeding over to my CB. I tried RFI filters, chokes, a capacitor across the power and ground and nothing worked. A good test is to power the light off of the bike using a car charger and see if it still interferes. In my case the light still emitted RF off of the bike, so there is no fix or anything you can add to the wiring because it’s not in the wiring. I returned them. What manufactures are doing these days is going away from the conventional voltage drop of resistors and using a pulse modulated voltage circuit. They are applying full power to the LED’s in a pulse. If it was constant it would burn it out, so they pulse the power. Unfortunately this pulsing causes RF. Most of the LED lights are made in China and there is no regulations like here for radio interference. I’m working with the factory Rep on a new set of lights and will have a write up soon on alternative lighting.
