They use that stuff here too. It makes it feel like the back of the bike is going to slide out from under you. I try to steer around them as much as possible.
Everytime I hit them it gets real squirrely. That being said, I have never heard of anyone ever going down because of them.
Originally Posted by ocezam
Yeah, 41 years and I've never heard of anyone either.
They are only a factor if you get skeered and go to over-correcting something that needs no correcting. Just stay smooth and ride right through them.........or put more wheels under you. You are gonna see more and more of that instead of new overlays because of the economy. We have some of the best riding roads in the country here, and they have been using "chip and seal" instead of new asphalt on a lot of them because money is tight......! (I'd rather have the tar snakes on old asphalt than the potential loose gravel issues on a new "chip and seal" road!!!)
They do a lot of chip seal here in Idaho too. All that small gravel sitting on top can make you feel like you're in a shooting gallery. We also get the tar snakes. Guess we're just lucky like that.
Yep they use that stuff here in Maryland. Main road towards my house they used that way to patch the road three years ago,,, they are just now getting the the point when warm where to you dont get that little wiggle when I turn into my neighborhood. NO FRONT BRAKE!! Friend forgot that and went down good!!!
yeah, i run southern maryland route 4 and the beltway. lots of times they are rotating their paving locations so it seems like the longest an area goes without paving is about a couple of years. in the mean time, they tar them up. they are even slick in cold weather, just not as bad. add a couple shakes of rain and yeah, its fun. not panicing is the key, and if you happen to be riding one when it happens, get off of it as smoothly as you can. ride safe
I've also seen that same kind of tar used on the ends of bridges, where the end of the bridge meets the asphalt street. They put down a strip about 10-12" wide. Same as with the snakes, they can be very slippery.
There's a bridge like this on a road I ride now and then. Right after the bridge, there's a 90-degree right turn. No matter what you do, makes the bike very unsteady making that right turn over the tar strip...
