Front Fender
Old Feb 26, 2007 | 05:58 PM
st john's Avatar
st john
Default Front Fender
Do I have to remove the front tire to remove the front fender?
At work and do not have access to my do it yourself book.
Thanks,
Glen
Old Feb 26, 2007 | 06:03 PM
bountyhunter's Avatar
bountyhunter
Default RE: Front Fender
You must remove...calipers/wheel...5 minute job!
Old Feb 26, 2007 | 07:57 PM
soos's Avatar
soos
It can be done without removing the wheel but it is much more difficult and not worth the trouble.
Old Feb 26, 2007 | 08:07 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
I did mine on the bike... removed the headlight complete from the fairing to get to the connector/harness for the light. Pulled the calipers, put a 9/16 socket on an extention and ran it thru the front wheel to get to the bolts. Beat the extention with a hammer to bend the locking tab out of the way so the bolts would spin out. you might have to move the bike a few inches to get at all the bolts.
Old Feb 26, 2007 | 10:07 PM
smknflms's Avatar
smknflms
...and that's easier than removing the wheel?
Later
Old Feb 26, 2007 | 10:43 PM
hd2007's Avatar
hd2007
If you have a good jack to get it high enough , leave the fender on , if not take it off no big deal
Old Feb 26, 2007 | 11:53 PM
frittsk's Avatar
frittsk
Did mine without removing the wheel. Didn't think it was that bad. The hardest part is bending back the lock tabs for the fender bolts.
Old Feb 27, 2007 | 12:53 AM
choochoo's Avatar
choochoo
well reading a couple replies here, but first why did you want to remove it anyway???
It can be done, but it's tight, especially without it being on a jack so it's straight up.
Getting the fender lock bolts lock tabs undone is a bitch with wheel on.
Putting back on use the tab plates, but instead of bending them use a little dab of red
locktite.
Fender tip light wire goes through the fender, so that needs to be disconnected.
Or cut and resoldered together and heat shrinked. why did HD do it that way??
Old Feb 27, 2007 | 01:10 AM
mikeisglidn's Avatar
mikeisglidn
you can do anything with torch!!
Ashnic
Milwaukee Eight (M8)
Oct 3, 2017 11:40 AM
peteperrone
Jul 2, 2013 01:08 AM
hoethree
Dec 1, 2011 06:43 PM
stevec314
Jan 8, 2008 04:33 PM
Blazer
Jul 14, 2005 06:32 PM
