monster oval mount
Old Jun 27, 2013 | 09:10 PM
decencyxdefied's Avatar
decencyxdefied
Default monster oval mount
got a used set from a guy who had them on an 11 electraglide..start putting them on my 08 street glide and the mount under the bag is different than the screamin eagle slip on..the current set up I have has the flat metal piece with 2 drilled holes about 3 inchs apart that bolt right up to the se slip ons. its located at the rear of the bag support when I mocked up the oval the mounts on the pipe were not only closer together but more towards the middle of the bag support..any ideas guys
Old Jun 27, 2013 | 09:40 PM
rufasim's Avatar
rufasim
I too just bought a set of MO's and noticed the same thing. The rubber mount slipped out of the saddle bag support. Took just a few minutes to put it back in place, but something else to keep an eye on and worry about
Old Jun 27, 2013 | 09:50 PM
decencyxdefied
Did u get urs mounted?
Old Jun 27, 2013 | 10:43 PM
big cahuna's Avatar
big cahuna
I just changed out a set of ovals. The holes lines up I had t o use 5/16 x 3/4 in bolts with them. If the holes are too forward, maybe you have them pushed on too far. You only need about 2 inches of the muffler pushed onto the head pipe. You can slide the bar and rubber hanger to where it fits best. Just make sure they are even, when you look at them from the side.,,
Old Jun 28, 2013 | 10:20 AM
decencyxdefied
had to get a set of hardware from v&h for 27 total which brings my total for a set of used ovals to $102..lol
Old Jun 28, 2013 | 11:29 AM
BCKNBLK's Avatar
BCKNBLK
Reverse the rubber mount so that the thicker side faces the back of the bike. I put a brand new set on my 2102 SG and had the same issues with the rubber mounts vibrating out towards the front of the bike so I reversed the mounts and everything has been fine for over 3k miles now.
Old Jun 28, 2013 | 12:30 PM
decencyxdefied
thanx for the heads up ill mount them that way from the start
Old Jun 28, 2013 | 02:50 PM
edpanz's Avatar
edpanz
I had a set of monster ovals on my last bike...they come with a set of brackets that slide through the rubber mounts in place of the O.E. brackets that came with the bike.
Old Jun 28, 2013 | 04:29 PM
decencyxdefied
Did yall like them?
Old Jun 29, 2013 | 08:16 AM
mikebaby's Avatar
mikebaby
The MO mount as angled on one end, so that it cannot slide beyond that.
decencyxdefied:
I LOVE them! The sound is very deep, but not obnoxious. They also really fill in the area under the bags. I used to have SuperTrapp SE's (pretty much the same thing as the Screamin' Eagle SE slip-ons, and I like these better. Here are some comparison photos:
mikebaby
barchetta
Sep 4, 2014 02:07 PM
SwiftyBKells
Apr 10, 2012 10:56 PM
Fenrir
May 14, 2011 05:06 AM
deadbug
Jan 18, 2009 07:18 PM
Mascman
Jul 23, 2006 03:36 PM
