Loose Throttle Cable
Old Jul 1, 2013 | 08:57 PM
06SGWA's Avatar
06SGWA
Default Loose Throttle Cable
So I bought chrome switch housings and am having a problem with the return cable falling out/not snapping into place. The other one snaps in and is tight. Is there supposed to be a c-clip to hold it on or is the hole in the new housing too large. Thanks.
Old Jul 2, 2013 | 05:43 AM
kyote's Avatar
kyote
I thought they had threads on them.. mine do, they screw into the switch housing...
also.. you can use the cable adjuster to make it a bit more snug..
Old Jul 2, 2013 | 06:33 AM
skully1200's Avatar
skully1200
Yeah there is supposed to be a small clip of some sort on the end of the cable. Never looked that close to see exactly how they attach. The cables should just push in and click into place in the switch housing. Maybe your clip got stuck in your old switch housing when you removed it? I am really just guessing. Good luck.
Old Jul 2, 2013 | 06:36 AM
skully1200's Avatar
skully1200
You didn't somehow switch the cables into the wrong holes did you? The throttle and idle cables are different sizes. You didn't force the big cable into the small hole? I hope.
Old Jul 2, 2013 | 07:07 AM
DEW2112's Avatar
DEW2112
Just had this problem with my throttle return cable. There is a very small clip on the end of the cable. I had to order one from HD, but in the meantime, I took my thumbnails and pulled the existing one further apart, sort of spread it open a bit further and that's all it took. I still have the new one in a bag (#11271 Retaining ring)for a 2002 FLHT.
Old Jul 4, 2013 | 07:02 PM
06SGWA's Avatar
06SGWA
Thanks for the help. I am tearing it back apart this weekend to see how these clips work.
WillyD
Jan 14, 2014 03:40 PM
cloudenbeck
Nov 16, 2012 03:53 PM
oinker02
Jan 17, 2010 08:42 AM
Viejo
Jun 22, 2009 12:58 PM
GLACIERPEARL
Apr 15, 2009 01:35 PM
