Screwed up...please help
Old Jul 3, 2013 | 07:36 AM
Michael Motorcycle's Avatar
Michael Motorcycle
Default Screwed up...please help
I went to gas station and filled my FLHX with 87 octane gas instead of 93 octane. I had about half a tank when I did this.
It seems to be running rough now. Only has 4200 miles on it.
Will this screw up my bike?
Should I put some octane booster in it? (if so, what kind?)
Any help appreciated...THANKS!
Old Jul 3, 2013 | 07:39 AM
circlenine's Avatar
circlenine
I am no expert, but I would say no, 3 gallons of gas will not kill your engine. Diesel on the other hand...
If you're worried, top off with 93 now, ride some more, top off again, ride some more, top off again...
(Just my .02)
Old Jul 3, 2013 | 07:40 AM
Scuba10jdl's Avatar
Scuba10jdl
Just go top it off with 93 and continue to top it off every 50 miles or so for a couple fill-ups. Then it will be diluted enough and you shouldn't need to worry about it.
Old Jul 3, 2013 | 07:42 AM
06Cummins's Avatar
06Cummins
Any octane boost will help look for the one that provides the most boost points. I don't think it will hurt it.
Old Jul 3, 2013 | 07:43 AM
WG2011's Avatar
WG2011
Your fine just fill it up with the 93 or whatever is recommended next time. Its not going to hurt anything for one tank. If your really worried run down about half of it and then fill it the other half with the correct fuel. Octane numbers will not hurt an engine as much as it will just not perform as well with the correct octane and if it were an automobile with a much larger tank menaing it would be using this octane longer it may start to ping. But even the pinging is not going to kill the engine its just not great for it. No worries, as said above diesel would be a whole nother story you would have to drain that out.
Old Jul 3, 2013 | 07:48 AM
TWIN CAM 96's Avatar
TWIN CAM 96
fill up with racing gas 100+ octane
Old Jul 3, 2013 | 07:50 AM
Captain Itch's Avatar
Captain Itch
Sponsor
Go ride your bike..
__________________
www.Captain-Itch.com
Old Jul 3, 2013 | 07:53 AM
ftworthcowboy's Avatar
ftworthcowboy
I did just the opposite the other day. I put more miles on my bike than my car and am used to grabbing the 93 Octane handle. After putting about $35 in the car I noticed I had grabbed the 93 Octane handle by mistake. Obviously the only thing it hurt was my pocketbook. LOL
Old Jul 3, 2013 | 07:54 AM
im's Avatar
im
Go ride. No big deal.
The worse thing might be that if you are in a high heat situation AND prolonged stop and go traffic the engine may ping/knock.
Old Jul 3, 2013 | 07:58 AM
CC Rainman's Avatar
CC Rainman
Just ride the bike. I use regular gas once in a while with no problem.
