Road King Classic
Old Jul 5, 2013 | 09:55 PM
ken6217's Avatar
ken6217
Default Road King Classic
Going to test ride a RK Classic tomorrow. Got to get an early start before the heat.
I had previously owned an Ultra Classic and been without a touring bike for a couple of years.
I was curious how the heat is on the '13's? Do you cook or is it not as bad as it had been on my 2008 Ultra Classic? Also can you resolve the heat issue (if there is any) with slip on's, K&N, and a Power Commander with a canned map?
Any other comments on the bike?
I still have a '95 Springer Evo and love that I can ride in 90 degree weather and not cook on it.
Thanks,
Ken
Old Jul 5, 2013 | 10:22 PM
dulley's Avatar
dulley
new head pipes ,either the pc 5 or the stag 1 down load ,I got a 2011 with the 103 ,first thing I did was power duels and stag 1 down load ,no heat ,now 2 years later I put on the high out put mufflers and the pc5 ,very nice up grade ,not the best but nice ,im very happy , it needs nothing now ,well maybe it needs cleaned
Old Jul 6, 2013 | 09:53 AM
Climb14er's Avatar
Climb14er
The only mod I've done with the 2011 RKC is a Stage One. Factory heat and stuffed cat lead to tons of heat.
Now, less heat, better breathing and exhaust flow, smoother performance and much better running engine.
Getting rid of the cat and opening up the airflow dropped the heat levels big time.
Old Jul 6, 2013 | 10:20 AM
Texas Fat Boy's Avatar
Texas Fat Boy
It will be hotter than your 2008, but you are probably gone for the test ride by now.
So, never mind.
Old Jul 6, 2013 | 10:42 AM
12XU's Avatar
12XU
De-cat the head pipe and alot of heat will be gone.
Old Jul 6, 2013 | 11:20 AM
zdrifter's Avatar
zdrifter
Went for a ride on the 4th on the RKC (stock) ... strong wind from left to right (20 knts +) coming back ... heat was off the chart on the right side (wind shadow) .. will be decatting this week ...
Old Jul 6, 2013 | 04:32 PM
bklynbob's Avatar
bklynbob
To do the job right ,you still need a cam with some overlap. you can throw all the fuel you want at the motor,it'll only cool it so much................
Old Jul 6, 2013 | 04:45 PM
Glockcubed's Avatar
Glockcubed
Do the stage 1 and the heat problem is gone.
Old Jul 6, 2013 | 05:12 PM
Tailsfrommycrib's Avatar
Tailsfrommycrib
Good luck and have fun! The RKC is an awesome bike and after 09 all the tourers got a major upgrade.
Old Jul 6, 2013 | 07:22 PM
Tommygun61's Avatar
Tommygun61
Good luck with the new bike. I just got mine 3 weeks ago.
