New rider here. I've been renting from the local HD dealer to ride several different MC's to determine what I want to buy. Since I'm not an owner (yet) I don't have an owners manual to refer to. What are the recommendations on rpm range for which gear. I'm not as concerned about shifting points. Looking more for what gear/rpm range for constant speed at a given mph. Any rules of thumb for this?
Welcome to the forums Rabell. 10 MPH for each gear. 10 MPH 1st, 20 MPH 2nd, 30 MPH 3rd, 40 MPH 4th, 50 MPH 5th, 60 MPH 6th. Thats a general rule of thumb I have seen in a few posts over the years but I like to twist on it a bit sometimes, lol. Hope that is what you asked for. If I am wrong, someone will set me straight.
See a pattern...now; I "don't" follow these speeds & ride by feel/RPM's. Shifting & gear selections, for my riding style, run between 2500 - 3000 RPM's and the only time I'm in 6th gear is on freeway @ +65MPH.
Nothing wrong with any of the suggestions, but looking for a RULE limits flexibility. Once you gain a bit of feel for the machine, you will find that higher gears work fine on level or down hill situations but at the same speed going up hill the machine needs a lower gear. Only experience will gain you that perspective. On stock TBW bikes, wide open throttle is not available, regardless of twist grip position, until engine rpm is above 3000. This knowledge will help in making down shift decisions for passing etc.
Don't worry about it as a new rider there or other hazards you need to pay attention to.
Just ride you will develop a feel for what the bike likes where the power band is and that may not happen until you get your own bike and ride for a while.
I keep my RPMs between 2500 - 3000 when riding in town, all gears.
I've been running TC motors since 2005. When cruising on "the flat" I also run mine between 2500-3000, TC's like it there. On hills, wind 'em up, they like that also.
I stopped looking at what speed I was shifting at and started looking at the RPM. It was usually around 2400 for all gears. But I try to not let it get below 2000 in any gear.
Like Sam said, in time you'll feel and hear your engine and know when to shift without looking at your speed or RPM.
The answers seem to confirm what I was thinking based on riding these last few days. 2400 - 2800 'feels' like the sweet spot. Seems to get laggy the closer I get to 2000.
