flairing holes strip
Old Jul 7, 2013 | 01:31 PM
rochkes's Avatar
rochkes
Originally Posted by littled62
had 2 of mine strip out a few years ago, got the repair ones from the dealer then I used a tap and die set to retap the holes, put a small amount of epoxy on each one then used a bolt and screwed it into the insert with a nut between the head of the bolt and the insert as a spacer, put the end in first that has a slot on it for a screw driver, yes I put them in upside down, the end with the slot in it is weaker, used a wrench to screw them in that's why the bolt, let the epoxy set up over night. I did all 7 while at one time, I've never had one come out again and I remove my fairing a lot
I don't think you put them in upside down. The way you did it is how they are meant to be used. The slot is so the insert will compress a little if it needs to when it is inserted.
Cheap, easy fix.
Dennis
Old Jul 7, 2013 | 05:26 PM
1flhtk4me's Avatar
1flhtk4me
Road Glides do not use metal inserts like on the batwing fairings.The inner fairing bolts on to the outer fairing with screws which screw into plastic.
Old Jul 7, 2013 | 06:23 PM
littled62's Avatar
littled62
Cheap, easy fix.
Dennis
ok I might be wrong about the way they go
Old Jul 7, 2013 | 06:34 PM
rochkes's Avatar
rochkes
I didn't know that. I have no experience with the rg fairings. That would explain the post about replacing all seven at the same time when the batwings only have three.
Dennis
Old Jul 7, 2013 | 07:19 PM
littled62's Avatar
littled62
the bat wing has 7, 3 at the top for the windshield and 2 on each side toward the bottom for the bolts that come thru from the back side (one by the speaker and one underneath by the forks)
Old Jul 7, 2013 | 07:58 PM
rochkes's Avatar
rochkes
Yeah, but I had never heard of anyone having problems with any other than the top three for the windshield. I guess it stands to reason if you remove and replace them enough, you'll have problems with all of them as they come from the factory.
Dennis
Old Jul 8, 2013 | 07:38 PM
littled62's Avatar
littled62
Dennis
the ones that came out on me where the top ones on both sides by the speakers, one of them pulled all the way out, when I got the fairing off had to hold the insert while I turned the bolt out, not really something you would think you would have to do to a 4 year old bike that cost over $22,000
Old Jul 8, 2013 | 08:12 PM
dulley's Avatar
dulley
I don't have a problem with the windshield ones its the ones that hold the inner to the outer
Old Jul 8, 2013 | 08:16 PM
Juan L's Avatar
Juan L
Moderator
Do you have room for well nuts?
http://www.mscdirect.com/product/677...S&026=nv&025=c
Old Jul 9, 2013 | 06:57 AM
1flhtk4me's Avatar
1flhtk4me
The plastic bosses for the sheet metal-like screws are only about a 1/4" in dia. IIRC.
bladeguy
Audio Systems
Oct 8, 2017 09:10 AM
bladeguy
Audio Systems
11
Sep 29, 2017 05:25 AM
SPARKY01
Oct 14, 2008 11:52 PM
roxnatwist
Feb 19, 2008 07:06 PM
