So I got a set of passing lights with turn signals. The problem is the wires from where in pined so I don't have the connector. Now theses light have 4 wires coming from each side. I need the connector for my 2005 RKC. But I can't seem to find it. I have googled it and search for 2 days. Thanks in advance for any help
Dont quite understand what you are asking. Are you asking where your connectors are located on your bike? Are you asking what connector you need to buy to add to the light bar to match what you currently have on your bike? Are you asking for a wiring diagram of how it hooks up? Can you post some pics and give a bit more detail? Sorry I cant help but its kinda vaigue.
You might try a dealership and try to get them to pull up a diagram of the lamp assemblies. Then see what the part number for the connectors is on the diagram. You have to start bigger a lot of times and work your way down.
Btw RKC in your case looks like Road King Custom by your pic but somebody could interpret it as Road King Classic which comes stock with a light bar.
Or get a service/electrical manual, best 120 bucks you will EVER spend on your bike. It will have the wiring diagram AND they explain what type of each connector the bike has with P/N.
If ya just need the connecters the pins go in go to the dealer and get them? They are in the parts book. Match the wires & connectors to the ones behind the headlight.
