Question on removing fork studs.
Old Jul 11, 2013 | 04:44 PM
Lone Dawg's Avatar
Lone Dawg
Default Question on removing fork studs.
Can I get you folks to give me some tips as how to remove the studs from the bottom of the right fork? Is it righty tighty lefty loosey? I will be installing Hill Country Customs custom fork end. The bike is a 2010 Electra glide ultra classic.
Old Jul 11, 2013 | 05:06 PM
mfortkamp's Avatar
mfortkamp
Yup just like a normal bolt. If it doesn't want to come loose you can hit the bolt with a torch to break the locktite. Don't get it too hot that you burn up seals or if chrome lowers you will blue the chrome
Old Jul 11, 2013 | 06:39 PM
Neil's Avatar
Neil
I ended needing to grab the studs with a set of vice grips due to the studs being chromed into the legs. Just double nut the studs and twist away. Good luck.
Neil
RDMC
Old Jul 12, 2013 | 05:51 AM
Lone Dawg's Avatar
Lone Dawg
A couple more questions:
- Is it best to mount the new chrome sliders on the bike first and then remove the studs or put the slider in a vise and remove the studs?
- Can some explain how to removing the studs using the double nut method?
Old Jul 12, 2013 | 07:16 AM
1flhtk4me's Avatar
1flhtk4me
Screw two nuts onto the stud then tighten the nuts together.Place a wrench onto the top nut and unscrew the stud.
Old Jul 12, 2013 | 08:33 AM
Lone Dawg's Avatar
Lone Dawg
Thanks. I'll give that a try.
Old Jul 12, 2013 | 09:16 AM
Def Mute's Avatar
Def Mute
By 'top nut'...
He is meaning the inner nut. The one closest to the fork. The outer nut would just twist away from the other and not let you remove the stud. You cinch the two nuts together, then putting the wrench on the inner nut, it tightens against the outer nut and causes the stud to rotate. Looking at the stud from the outer end, turn counter clockwise. (Righty tighty, Lefty loosey) Hope that makes sense...
Old Jul 12, 2013 | 11:38 AM
Lone Dawg's Avatar
Lone Dawg
Originally Posted by Def Mute
By 'top nut'...
Thanks for the clarification.
Old Jul 12, 2013 | 04:19 PM
Lone Dawg's Avatar
Lone Dawg
IT WORKED! Thanks again.
Old Jul 13, 2013 | 04:17 AM
Def Mute's Avatar
Def Mute
Cool deal...
For future reference, that is called "Double Nutting a Stud"
mhodge
Aug 5, 2017 05:40 PM
teeboz
Feb 5, 2012 08:43 PM
2K1FLHPI
Oct 12, 2009 11:24 PM
HGM
EVO
Jan 25, 2008 07:18 PM
03 Softail
Apr 24, 2006 12:37 PM
