New primary seals.. Same Leak..
Old Jul 11, 2013 | 10:35 PM
SF_BluCllr's Avatar
SF_BluCllr
Default New primary seals.. Same Leak..
Started out as a small leak that i figured i might as well take care of while i got the bike on my buddies lift. Went to the local shop and got all the seals for the inner and outer primary. Took it all down and cleaned it and put in the new seals.
First.. oil in and everything torqued.. jackshaft spins and not start! Opened it all up again and realized i had put the coupling in backwards. Then buttoned it all up again.. torqued and checked.. STARTS! Now.. Leak is STILL THERE! And now seems to be a little worse.
Any ideas here? Checked other threads and it seems like ive done everything rite. Maybe a trick to anything? Something else i should check? The one thing i DID notice was when i took the inner primary off, the bolts holding it on seemed like they almost had a dab of silicon on the end? Taking it all off again tomorrow after work.. JOY
Old Jul 12, 2013 | 05:22 AM
timvan's Avatar
timvan
RTV around the mounting bolts, they will leak.
Old Jul 12, 2013 | 07:05 AM
SF_BluCllr's Avatar
SF_BluCllr
thanks, ill give that a try
Old Jul 12, 2013 | 07:11 AM
1flhtk4me's Avatar
1flhtk4me
Did you check the shift shaft seal?
Old Jul 12, 2013 | 07:14 AM
Def Mute's Avatar
Def Mute
If the original leak was from a shaft seal...
Then perhaps the shaft bushings are bad also. If the shaft is not stable, the seal will leak. And YES, do put RTV black high heat sealant on the bolts going into the engine block and tranny. It isn't necessary on all of them, I believe the two inside the primary cover going into the crank case, and two (or three) to the right of that going into the transmission case. You should also follow the tightening sequence in the service manual. When tightening the primary, it will distort as you go. Torque and sequence is essential...
Old Jul 12, 2013 | 07:28 AM
bigskyroadglide's Avatar
bigskyroadglide
just experienced this same issue on my 12 CVO. Took primary off, doing some work, went to put back on and ended up with leak. Had bought the gasket online, looked at the new vs old and old was somewhat thicker. Went to HD and bought a HD gasket, dropped the primary again, changed out gasket, followed the correct sequence in tightening the bolts and no leak.
I think it was gasket thickness, but i could be confused. if you have your old gasket, check it vs new one, if they are same thickness, ignore my experience.
Old Jul 12, 2013 | 07:48 AM
mr396's Avatar
mr396
The service manual says to replace the sealing fasteners. There are 5 of them that bolt the inner primary case to the engine. These bolts have a rubber type of gasket on them.
On the primary there are several seals:
- the crankcase gasket
- the mainshaft seal (goes over the IPB)
- the starter O ring
- the outer primary cover gasket
- the derby cover gasket
- and obviously the o-ring from the drain plug
are you sure the leak is coming from the primary? There is another seal from the transmission right behind the belt sprocket (and IPB).
Old Jul 12, 2013 | 10:06 AM
djl's Avatar
djl
Very common problem. First things first; are you sure the leak is primary fluid and trans fluid?
Sounds like you are working on a pre '07 model? In addition to the seals previously mentioned, there is the 5th gear/main shaft seal and quad seal. Did you check the IPB to verify that it has not walked into the 5th gear/main shaft seal? Very common source of inner primary leaks. You could have nicked the IPB seal when reinstalling the inner primary housing if you did not wrap painters tape or otherwise protect the IPB seal; very easy to do as the main shaft splines are very sharp.
Silicone behind the bolt heads/locks and the housing is also necessary. I would not silicone the bolt threads, not necessary, doesn't seal anything. I make it a habit of replacing every seal that lives behind the inner primary whenever I have to pull one. Parts are cheap and repeating the procedure sucks.
Old Jul 12, 2013 | 10:54 AM
blackflame's Avatar
blackflame
Good thread i'm getting a leak too, and looks like it's coming from up in the pulley area. But will wait until winter to fix. Just have to check my levels.
Old Jul 12, 2013 | 06:26 PM
SF_BluCllr's Avatar
SF_BluCllr
I dont think its comming from the shift shaft seal. But i picked one up anyways and going to replace it while its accesible. I could tell theres a little moisture around it, but not nearly enough to be the main cause of my leak. Bikes an 00 FLHT. Went step by step with my clymers bible and it said nothing about a tourque sequence! Can you guys enlighten me? I didnt just crank down one side and then the next. (Did kind of like a tire star pattern) But im surprised it didnt say anything about that. Heading to the shop to pick up some oil, silicon, and pick their brains a little more. Let you guys know how it goes.
