Suspension gurus- Loading question:
Old Jul 14, 2013 | 08:26 PM
JCleary's Avatar
JCleary
Originally Posted by grbrown
All things in life are a compromise. If you can't be convinced that coilover shocks can give great results, there is not much hope for you! What else is there out there?
Well, I've spent thousands on coilover shocks and have not found a good compromise. I decided to try what I was told was the best air ride, Legends.
I'm just tired of throwing good money after bad you know?
I appreciate your advice. Thank you.
Old Jul 14, 2013 | 08:37 PM
'05Train's Avatar
'05Train
Sorry man, I thought I was clear. My wife and gear only add about 180 pounds to the bike. The JRIs have no issue dealing with that.
Old Jul 14, 2013 | 09:24 PM
FastHarley's Avatar
FastHarley
Former Sponsor
Default Offer
Originally Posted by JCleary
Thank you for your input Howard.
I completely understand how suspension works.
I stated that the Ohlins were undersprung. Which the particular shocks I had indeed were for a two-up load. I understand spring rate just carries the load. The dampening is a separate issue.
My comment was that the adjustable dampening seemed to have enough range of adjustment to overcome a much stiffer spring rate (and lighter, for that matter). Apparently I need to be more specific when typing a post, as implications cannot often bee seen when reading a post. So, in short, the shock itself could be adjusted to compensate for a spring with a higher spring rate, or lower spring rate should I choose to change it out. Of course you know that too little dampening with a stiff spring results in a pogo effect. I've spent many hours adjusting preload and clicker adjustments to get the ride quality I desired.
So far in this thread, I've received some insightful comments from several members. Only grbrown has actually directly answered my question, which was:
How big of a weight difference can a coil-over shock setup compensate for?
And according to him, a 250lb swing is not an issue for his set of Ohlins.
So far with the Legends, I've noticed that while the spring rate is almost infinite, the dampening is best suited to very heavy loads. Only if there was a clicker adjustment on the Legends...
I'm not opposed to the purchase of another set of Ohlins or JRI's. I just want to know the set can cover the weight difference and provide a good ride both solo and two-up.
You do not need another set of shocks. Your shocks can be made to do what you want. If your weight range is above what you wrote down on your build sheet, I can correct it. You do not need to spend any more money as you have done it with me once already. Despite the torrential 6"/hr of rain today & yesterday and my electricity going out sever times and my internet & server getting disrupted, I always answer my phone (during reasonable hours) & when God cooperates with me on my suspension plans. There is no reason why you can not get the proper ride you wish without spending a dime. I do not give tail light guarantees but my customers are supported for their life (again with the) & when God cooperates with me on my suspension plans. I can not make myself any plainer than that. You will never get the ride out of the current plan you have hatched. Don't you think I have tested them on our Shock Dyno and than taken apart every shock to see what and how they work. The shop Dyno cost more than most houses and the little one cost $26,000 that is mounted in the Sprinter Van. Go to Sturgis and you can see all of the aforementioned shocks apart and the twin with a Dyno sheet. Than you will see the truth as the shock Dyno does not lie. I can not give you a ride like one of these however as you would have to go to DreamWorks.
Old Jul 14, 2013 | 09:53 PM
fz4k98's Avatar
fz4k98
You may be looking for something that just is not possible. Sometimes compromise and realizing it is what it is brings acceptance.
I rode 4 different BMW's for the 20 plus years before getting my road king. I also borrowed, other bikes. By far the best riding suspension bike is a GS BMW.
I rode 600 - 750 mile days on BMW and felt better than a 300 mile day on my road king. The road king was grinding parts on corners during the break in period.
That said, I still like the road king over the BMW because I changed what I was looking for which is more laid back shorter trip cruising and I found the perfect bike to match it.
I put Ricors in the front and it made the back stand out terrible. I put Ricors in the back and am now wondering about the seat. I also realize I am chasing something this bike will not do which is be comfortable when compared to other bikes. But I still want the road king for what it is.
Old Jul 15, 2013 | 07:03 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Default Same Shocks
After I was with Ohlins for a while developing and promoting Ohlins shocks, once I was done with what they had available for HD's I proposed and Ohlins responded by making my first shock to add to the HD shock line-up. I took a BMW R 1200 front shock & fitted by modifying the parts Ohlins had available and fitted it to a Harley. The first one was a HD_909 A.K.A. HD #3~#3. These are the same shocks except for the actual dimensions, shim pack (valving), orientation, and mounting. The BMW Ohlins version is many times better than the stock O.E.M. BMW suspension. That is correct, no difference.
To answer the OP's question, the spring is there only to overcome gravity. That's it. I do not know the weight difference between one up and two up I have successfully installed many up to a 200 pound passenger (more than the one up rider). If the rider is in the mid 150 ~180# mark and wishes to put on more than a 175# passenger for a 70% single & 30% two up situation than a second set of alternative springs are necessary. Trucks have air bags the same as the shocks currently on your bike. Trucks will ride like a truck with that technology. That is the options available when hauling around more weight than
If anyone has been around here for any length of time they would remember the development if that subject was of interest to them. The same HD-#3~#3 is the same shocks that the OP had on his bike. The OP can get his bike to ride as good as a Harley can within the limitations of these Ohlins shocks. This means that these shocks need to have proper adjustment. If this customer would visit me either at my Florida address of one of the shows I am attending, I can guarantee 100% satisfaction within the limitations of the Ohlins #3~#3 shocks.
Old Jul 15, 2013 | 08:27 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Default Customer number
I have spent the last 2 1/2 hours trying to find anything related to JCleary under your name in my customer data base. I am trying to research your shock and build sheet. I can not find anything with the name of J anything Cleary. Please e-Mail me your name and any other information you may have such as customer number, approximate date of sale, customer name it was bought under, or any scrap of help. I take customer satisfaction very seriously. As of now I have no record of your sale from me/motorcyclemetal.com. Please help me help you.
Old Jul 15, 2013 | 09:24 PM
fz4k98's Avatar
fz4k98
I guess my point originally was more along the lines that you can work and rework shocks all you want but there will be a point of diminishing returns as the rest of the bike may become the limiting factor. There is just so much a shock can do and there is a point where future enhancement is not going to give the payback wanted. What made the GS ride so different had more to do with the rest of the bike than the shocks.
Old Jul 15, 2013 | 09:52 PM
cycle crazy's Avatar
cycle crazy
Great customer service Howard!!! I'll be calling very soon for recommendations (09 Streetglide). Gotta do some home work first...I'm a newbee at this.
Old Jul 15, 2013 | 11:27 PM
JCleary's Avatar
JCleary
Thanks for all the advice. I may be calling, Howard. I'd like to visit in Florida or at a rally, but it's a bit far for me to ride unless I'm laid off or retired. As far as the old shocks are concerned, they're gone along with my old bike.
Old Jul 16, 2013 | 03:32 AM
grbrown's Avatar
grbrown
Red face
Compared with stock and the cheaper aftermarket shocks there is a world of difference with a set of custom-built ones and not a great deal of difference on price. Diminishing returns? Emphatically no! At least not with what we currently have access to, courtesy of Howard.
As for GSs, Mrs B and I travelled with several of them through Europe for 2,500 miles on our old Glide. The remarkable thing to us, from the comfort of our #3-3 Ohlins, was how much they all got blown around in cross winds and how often they changed gear. I don't think they represent any standard a Glide cannot be compared with - after a few modest improvements!
