No throttle response
Old Jul 13, 2013 | 02:24 PM
jibbyvan's Avatar
jibbyvan
Default No throttle response
My cruise control keep blinking on dash
when it happens I have no throttle
2009 road king classic
Old Jul 13, 2013 | 02:31 PM
mkguitar's Avatar
mkguitar
the throttle body has a plug at the 7 oclock position ( feel behind the air cleaner).
unplug this and clean the contacts on both sides.
I use a fiberglass nic-sand pen ( some use contact cleaner spray...make SURE that it is plastic safe)
put it back on.( some use a dielectric grease)
then cycle the ignition 4 times to reset the throttle position
with right hand, turn on ignition switch...wait until fuel pump primes and stops...wait a sec...turn ign switch off.
repeat
this is all assuming that nobody has tried ( and failed) to wire up a bar swap
mike
Old Jul 13, 2013 | 02:37 PM
jibbyvan's Avatar
jibbyvan
thanks i'll try it
Old Jul 14, 2013 | 11:48 AM
jibbyvan's Avatar
jibbyvan
thanks it worked
Old Jul 14, 2013 | 12:04 PM
cass's Avatar
cass
repeat
mike
Originally Posted by jibbyvan
thanks it worked
i love it when a plan comes together......lots of knowledge in this forum.
Big Panda
EVO
16
Jan 9, 2017 07:34 AM
Bowyerde
Jul 6, 2014 03:47 PM
ZD
Mar 7, 2014 09:38 AM
osudvm
Jan 20, 2013 05:54 PM
woosh
Jul 24, 2012 12:23 PM
