no power
Old Jul 14, 2013 | 07:37 PM
bigdog1949's Avatar
bigdog1949
Default no power
installed tw26 cams this morning put in new fuel moto map,bike has no power,idles nice,runs quiet, used sc quick push rods 2.5 turns ,kinda lost !!
Old Jul 14, 2013 | 07:38 PM
rooti's Avatar
rooti
call fuel moto for another map
Old Jul 14, 2013 | 07:55 PM
stro1965's Avatar
stro1965
Describe "no power". Are you sure the cams are timed correctly?
Old Jul 14, 2013 | 08:17 PM
bigdog1949's Avatar
bigdog1949
gonna open up the cover in the morning,and check it;will **** me off if its wrong !!!!,havin a heat wave this week,thank u guys for the quick comeback !! no power,open throttle,drags on acceleration,like i'm pullin a load
Old Jul 14, 2013 | 08:23 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Could be sumping if you pinched or damaged one of the oil pump o-rings. You should replace all three during a cam swap in my opinion just to guard against this issue...which is more common than you think.
When you pull the cover and more oil comes out than should come out, that will be a good indicator. (if this is your problem)
Old Jul 14, 2013 | 08:38 PM
stro1965's Avatar
stro1965
Should show low on the dipstick too, right?
Old Jul 14, 2013 | 09:01 PM
Lowcountry Joe
A little, but more noticeable will be the ever increasing oil temperatures. This is when it pays to have an oil temp gauge. Happened to a friend and his oil temps would keep rising and got well over 300. He pulled the cam plate, and discovered he had pinched in half the main O-ring on the oil pump. Half of it was lying in the bottom of the cam chest. Replaced the O-rings and the bike ran perfectly.
Old Jul 14, 2013 | 09:29 PM
bigdog1949's Avatar
bigdog1949
I guess i'll know tomorrow !!,thanks,if I was one tooth off would it do the same thing ??
Old Jul 14, 2013 | 09:51 PM
bigdog1949's Avatar
bigdog1949
checked the oil down 1/2 a qt,oh well !!
Old Jul 19, 2013 | 08:09 PM
bigdog1949's Avatar
bigdog1949
Default no power
took the cams out ,found front cam to be 1 tooth off ,went back to bike shop,they will change tomorrow,was a real pain the *** .!!!!
