I left the house around 2 AM this morning to go to work...about five minutes down the road all my gauges stopped working except for the speedometer. Lights on those gauges went out also. Any idea what it can be? Its a 03 Ultra classic Electra glide.
Thanks, Vinnie
Vinnie, when that happened to me, I found my connections at the battery loose. This has happened two or three times in the four years I've had my latest scoot.
Hope this helps! :-)
aka Bob
ps. If you think about it, replay with the actual cause and remedy! Thanks
Reason: because I can
check the ground under the faring it behind the cigarette lighter attached to the fork frame when I did my bars it came off and had no gauges except speedo
