Lift Table
Old Sep 4, 2013 | 06:01 AM
  #111
DXHD $100's Avatar
DXHD $100
Originally Posted by Egldr05
It's not the same as I got either, mine is definitely thicker. Very little if any flex.
Rick
Can anyone show a picture of their locking bar?
Old Sep 4, 2013 | 06:49 PM
  #112
1st 96 ultra's Avatar
1st 96 ultra
Originally Posted by Lakerat
That bar with the ring through the hole in your photo is not the same as what came with mine that was purchased in December. Mine flexes with the Ultra, but not much.
a little flex is a little bend and will break one of these times , if you want to trust your bike and life on that its up to you but when I think I need a table if ever I will spend a little more money , IMO
Old Sep 5, 2013 | 11:04 AM
  #113
hd_rolling's Avatar
hd_rolling
Not the same bar that I have either, you sure you didn't get the atv table? You might need to bleed your system?
Old Sep 5, 2013 | 12:11 PM
  #114
Broncolou's Avatar
Broncolou
6th Gear
I have an older model of the same lift. It doesn't have a locking bar. It has holes in the riserbars underneath to slide a bar thru. I use an old sprint car swaybar thru the holes. Never needed it but I always use it while its up......FWIW
Old Sep 5, 2013 | 12:47 PM
  #115
Lakerat's Avatar
Lakerat
I'm no metallurgist but worked in maintenance/repair machine shops from 1968-2006 so I have a pretty basic understanding of metals and that slight flexing is of zero concern for me. Being bent without coming back is, but the photo posted doesn't appear to be the same locking pin as what I have.I have yet to see or read about proof of a mechanical failure of any part of a Harbor Freight table lift and there are plenty of them out there.
Old Sep 5, 2013 | 01:39 PM
  #116
DXHD $100's Avatar
DXHD $100
It did not fail the pump held it up very nicely; going back to the picture which started this thread mine looked just like one but I cannot tell by the picture what size the bar is. As I have said before I could of use another type Bar or re-engineered the whole safety lock system. I am not trying to bad mouth the lift I did not expect it to be a well engineered as the more expensive one but I just can't bring myself to keep something I personally can not trust no matter if it cost $299 or $2299. I still would like to see pictures of the other bar everyone is talking about so maybe I can go back to the store check the other lifts they have in stock.
Old Sep 5, 2013 | 01:52 PM
  #117
hd_rolling's Avatar
hd_rolling
This is what mine looks like, just bought the lift last month on line.
Old Sep 5, 2013 | 02:59 PM
  #118
DXHD $100's Avatar
DXHD $100
[quote=hd_rolling;11729322]This is what mine looks like, just bought the lift last month on line.
You are right it is very different they definitely spent a little more on your, mine looked like they took a straight 5/8 soft steel rod and drilled a hole and put a key ring thru it. I quest I could have let the pump hold it up but if letting it down slowly did this amount damage to the bar what would happen if the pump failed completely? That would turn into a " AW SH#$" moment very quickly. Thanks for your picture ride safe.
Old Sep 5, 2013 | 03:22 PM
  #119
DXHD $100's Avatar
DXHD $100
Hey hd rolling I am going to beat this dead horse a little more after seeing your I when back to the HF web site and looked very closely and I discovered 2 things 1st they both had the same bar as your, you can see the loop on the end 2nd both have the pump levers on the forward end mine was on the left rear don't know if that make a different but I think it odd to switch ends and bars I think it worst a another trip to the store.
Old Sep 5, 2013 | 03:23 PM
  #120
son of the hounds's Avatar
son of the hounds
This is what my bar looks like and it does not bend.
The reason I switched from Handy to Harbor Freight is that I have a small garage and it helps me when I am not working on a bike, to place it up against the wall.
