Lift Table
Old Jan 15, 2014 | 03:29 PM
  #141
hd_rolling's Avatar
hd_rolling
Originally Posted by 472viper
Thanks for setting me straight. He said drill rod, 1020, 1021 whatever it takes. (hope you remember that line in the movie). He probably said 7/8ths and I remembered 5/8ths.
You think 50,000 psi wouldn't hold it ? I'll look for some 1144.
Instead of making the rest of us look at the screen and scratch our heads, would it be possible to post a link to were you can buy what ever the hell it is you guys are talking about?
Thanks, and please don't forget the pictures!
Old Jan 15, 2014 | 03:33 PM
  #142
472viper's Avatar
472viper
Check my shopping cart. 0.875 dia cut to 24" lenth.
http://www.onlinemetals.com/basket.c...TOKEN=47867375
Old Jan 15, 2014 | 03:39 PM
  #143
Lakerat's Avatar
Lakerat
Post 139 had a link also.
472viper, just for the hell of it, let me know when yours is delivered, I may use your supplier when I'm ordering metal only. Exact same price on the Stressproof.
Old Jan 15, 2014 | 03:45 PM
  #144
hd_rolling's Avatar
hd_rolling
Ahh, and thank you.
Old Jan 15, 2014 | 08:03 PM
  #145
472viper's Avatar
472viper
It's in my cart but I did not pull the trigger to check out.
Shipping is almost as much as the cost of material, I am going to check local first and see if I can avoid the shipping cost. I have bought from them before, they have always had in stock what I was looking for and quote is for 3 day UPS shipping.
Old Jan 16, 2014 | 12:02 PM
  #146
Lakerat's Avatar
Lakerat
Ordered Tuesday night. Coming from Atlanta and will be here in the boonies Monday.
Line Product Ordered Shipped Balance Price Total
1 6628K52 High Strength 1144 Medium Carbon Steel Rod, 7/8" Diameter, 3' Length 1
Each
1 0 17.51
Each
17.51
2 92196A736 18-8 Stainless Steel Socket Head Cap Screw, 1/2"-13 Thread, 6" Length, Packs of 1 4
Packs
4 0 5.04
Per Pack
20.16
3 5321K14 Worm-Drive Hose & Tube Clamp with 410SS Screw, 7/32" to 5/8" Clamp Diameter Range, 5/16" Band Width, Packs of 10 1
Pack
1 0 7.20
Per Pack
7.20
4 5416K11 Worm-Drive Hose & Tube Clamp with 410SS Screw, 7/16" to 25/32" Clamp Diameter Range, 1/2" Band Width, Packs of 10 1
Pack
1 0 9.55
Per Pack
9.55
Merchandise 54.42
Shipping 8.95
Total $63.37
Old Jan 23, 2014 | 04:42 AM
  #147
just plain john's Avatar
just plain john
Heads up, the HF lift table is $339 this week
Old Jan 23, 2014 | 07:44 AM
  #148
hd_rolling's Avatar
hd_rolling
Digging up an old thread, but not that old.
I have sung the praises of the HF lift table for many years, having owned two in the course of 10 years.
I have noticed though that in order to keep cost low, they have cheapened this lift table up in some key areas.
The HF lift table used to have a fairly decent wheel vice. I had one on my first HF table. That changed to a POS that HAD to be changed out. But HF does have a good Condor style chock that works really well so it was still a good bargain.
It seems to me that the safety bar has now been compromised. I never noticed any flex in the safety bar of my first HF table and had many many big heavy dressers on it without problem.
Here is a pic of the safety bar of my current HF table bought about a year ago. The table had a friends Kawasaki 1600 Nomad on it at the time.
I don't think any "safety" component should do that. I have been advised to replace that bar with a piece of 5/8ths inch drill rod, which I'll do.
I'm going to keep my table and replace the safety bar, anymore I only use the table a couple times a year, I'm fully aware of it's limitations and am comfortable with it's use.
But I don't know if I could recommend this table in good conscience if I have to say "the wheel chock is junk and so is the safety bar but other than that it's a good deal".
They may have just cut too many corners to justify a recommendations any more. That's too bad, I have enjoyed my HF table lifts for many years.
I've been looking at your picture and can't wonder if the reason your support beam is bowing like that because you have your side supports adjusted too high so the middle of your lift isn't touching the ground? No way your wheels should be that far off the ground, I bet if you lower it down it wouldn't bend like that!
Old Jan 23, 2014 | 08:38 AM
  #149
Tucker99's Avatar
Tucker99
Can't lower the frame to the ground. The wheels will keep it from touching.
Old Jan 23, 2014 | 09:10 AM
  #150
chris h.'s Avatar
chris h.
The issue with the safety bar has been brought up before. It is a known defect, I believe they substituted cold rolled with steel with hot. Supposedly if you contact customer service they will reimburse you if you go buy your own bar.
