Lift Table
If you're happy with that lift, then peaches for you.
I saved my nickels and dimes until I could afford a lift made in the USA.
1) What jack does everyone use to raise the bike on the lift for tire changes, etc?
2) How carefull do you have to be when shaking and grunting that big nut while trying to loosen it? Have never seen one in person and a little concerned about stability.
3) How much lateral movement can it take?
4) Can you run the bike on the stand?
Thanks Guys
Yep, been using my Sears jack for years and my old back is starting to feel it's age. This may be the answer.
2. I yank, grunt, jump on mine. Use good tiedowns.
3. I move mine around, not sure what you mean.
4. I do, but be dam careful that your tiedown straps are away from hot parts like the exhaust. I have an airhead BMW with the pipes running in a bend forward, right next to the strap. Oops, hot exhaust and nylon straps do not go together. Otherwise I often test run my Harley's to check for leaks, check torque on bolts, etc.
HF jack for when I need/want to lift the bike rather high.
On the HF jack, it's wiggly as all get out while jacking it up. Even sitting down on the safety locks theres some wiggle. Especially raised up high. And because it's a small footprint under the bike, I need to be carefull what things I'm taking off so it doesn't tip fore or aft, like when you drop the rear wheel. All in all, it's fine and doesn't worry me, but I don't go nuts on it either.
