My Radio is Possessed
Old Jul 17, 2013 | 04:44 PM
Ron750's Avatar
Ron750
Default My Radio is Possessed
My 2003 FLHTCUI has had an intermittently responsive mode change switch for about a year. Usually if I hit it about 20 times it will eventually switch. I have a squeak in my fairing also, so I know I probably have a broken bracket, and was going to order the Ragan brackets, but I never did. Too cold to work on in Winter, and would rather ride in Summer.
So of course, today, the day before I leave on a 4 day trip, my radio goes bonkers. Was trying to switch radio stations, but the seek button raised the volume to the max. Then volume and even power off button wouldn't respond, so I had to shut the speakers off to avoid getting run out of town for blaring at stoplights at max volume.
Should I take my fairing off now, or wait til I get back from my trip? Any way to repair the radio or will I have to sent it to Iron Cross anyway? Is taking the fairing off tricky and probably break something, or is it easier than it looks?
Thanks
Old Jul 17, 2013 | 05:24 PM
JohnSWA's Avatar
JohnSWA
The fairing is a piece of cake! 2 bolts on left side, 2 bolts and right and the three bolts that hold your windshield on. All #27 torx bolts. Good luck!
Old Jul 17, 2013 | 05:44 PM
Ron750's Avatar
Ron750
Thanks. Is it really necessary to disconnect the battery like the service manual tells you to?
Old Jul 17, 2013 | 07:05 PM
42gunner's Avatar
42gunner
Old Jul 17, 2013 | 07:24 PM
Harleypingman's Avatar
Harleypingman
The vendor of your OEM radio was Radio Sound. Call them,502.267.6768.
Carl
Old Jul 17, 2013 | 08:41 PM
T_Dogg80's Avatar
T_Dogg80
I had the same problem. I had a loose ground in addition to a broken bracket. You don't have to unhook the battery, actually, leave it plugged in so you can test the radio as you go.
The fairing will take 5 mins to take off the first time. It's easier than you think!
Old Jul 17, 2013 | 08:48 PM
CGP93's Avatar
CGP93
From: Orig Surfers Paradise Australia, then Riyadh Saudi Arabia, Tokyo, Toronto, now So Cal
Dont be scared of the fairing removal - its easier than you think, have someone hold it as you remove the final screws, just to be safe so it doesnt drop on your fender. Take your time gently unscrewing the 7 Torx (#27) screws and your good.
Oh and when reassembling tighten the screws GENTLY - they can strip easy and cause some hassles
Old Jul 17, 2013 | 09:16 PM
T_Dogg80's Avatar
T_Dogg80
I didn't have any problems, but do make sure the screws go in without stripping. Just take your time. This is an easy job.
Old Jul 17, 2013 | 09:25 PM
Ron750's Avatar
Ron750
Thanks guys. I'll take it apart this weekend.
Old Jul 17, 2013 | 09:35 PM
CGLTD's Avatar
CGLTD
Have you had the bike since 03 and never had the fairing off? Anyways, I seem too take everything apart at one point or another! Everyone in this thread was spot on. Have fun!
