Chirping Road King
Old Jul 19, 2013 | 11:25 AM
simp6216's Avatar
simp6216
Tightened the belt to 1/2" deflection. What a pain in the a**. My pipes won't come off because I used exhaust sealant per Rinehart's instructions. Need to get one of those torque wrench adapters for the rear axle. But, the chirp is still there. I'll check the brakes next. One thing at a time.
Old Jul 19, 2013 | 11:39 AM
mkguitar's Avatar
mkguitar
can you get access if you pull the shocks and drop the axle below the pipes ( bike supported on jack)
mike
Old Jul 19, 2013 | 12:51 PM
simp6216's Avatar
simp6216
I dropped the shocks and readjusted the belt. Now it's a little tight. Deflection is just under 1/4". Brakes look fine. Took it for a short ride and no chirp. Hooray!!!
Must have been a loose belt. I'll take it for longer ride later this evening. Thanks for all the suggestions. Now for a nice cool shower.
Old Jul 19, 2013 | 12:54 PM
jcallesano's Avatar
jcallesano
Horay
Old Jul 19, 2013 | 01:13 PM
Pumba11's Avatar
Pumba11
Originally Posted by 01Byte
Tell your wife to lean to the right and see if the chirping sound switches sides.
I get it! Good one.
Old Jul 21, 2013 | 11:12 AM
giacomo56's Avatar
giacomo56
Default Chirping solved !!! On my RK
Theres a rubber strip thats between the chrome quick install set up that runs along the fender...well it worked loose and there was about 2inches sticking all by itself...removed it and the chirping stopped...i am going to put it back but i am going to glue it so that it doesn't slip down again....funny though i could hear the chirping on top of all the damn noises coming from my front end..
RiverB
Dec 6, 2014 06:32 PM
ShovelnTC
Nov 24, 2013 09:50 AM
Flying Horse
Jun 27, 2011 07:18 PM
labdog
Sep 2, 2007 09:39 PM
sliderking
Aug 23, 2006 10:42 PM
